Aller au contenu principal
How to fix a break in a Belkin Lightning Charger Cable
Marcus Watson
Marcus Watson et 3 autres contributeurs
Dernière mise à jour le March 15, 2023
1 - 15 minutes
Modérée
Images incohérentes
Nécessite plus d'images
Belkin lightning charger cables are a popular choice for those who need to charge their Apple devices. However, over time, these cables can become damaged and develop breaks or frays. A break in the cable can be frustrating and may even prevent you from being able to charge your device. While soldering is a common method for repairing damaged cables, not everyone has the necessary tools or experience to do so. Fortunately, there are alternative methods to fix a break in a Belkin lightning charger cable without soldering. In this guide, we will explore some simple and effective techniques for repairing your cable and restoring it to working order. Whether you are looking to save money on a replacement cable or simply want to learn some basic cable repair skills, this guide is for you.
Please note that this isn't actually a repair and more of a "Quick Fix". As opposed to crimping the cable or soldering it this fix will not provide much structural support, so you may simply pull your cable apart if you pull too hard on it.
  1. How to fix a break in a Belkin Lightning Charger Cable, How to fix a break in a Belkin Lightning Charger Cable: étape 1, image 1 de 1
    • Unplug the charger before starting with the repair.
    • Locate the damaged area on the charger.
  2. How to fix a break in a Belkin Lightning Charger Cable, Cut out the broken section: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    Flush Cutter
    $29.99
    • Cut out the part where the wire is broken using a pair of wire cutters.
  3. How to fix a break in a Belkin Lightning Charger Cable, Strip the cable: étape 3, image 1 de 1
    Flush Cutter
    $29.99
    • Strip off about 3cm of the black insulation with the wire strippers to expose the red and black wire on both parts of the cable.
    • You can use your flush cutters or a knife as an improvised wire stripper by cutting just enough so that you don't damage the small wires inside and pulling the insulation off.
    • Be safe when using the flush cutters or a knife: Pull away from your face and body when stripping wires.
  4. How to fix a break in a Belkin Lightning Charger Cable, Add Heat-shrink tubing: étape 4, image 1 de 1
    • Slide about 1.75 of Heat-shrink tubing on a black and red wire each.
    • Slide about 5cm of Heat-shrink tubing on a charger cable.
  5. How to fix a break in a Belkin Lightning Charger Cable, Strip the wires: étape 5, image 1 de 2 How to fix a break in a Belkin Lightning Charger Cable, Strip the wires: étape 5, image 2 de 2
    Flush Cutter
    $29.99
    • Strip off about 1cm of the insulation of each of the wires with the wire strippers.
    • You can use your flush cutters as an improvised wire stripper by cutting just enough so that you don't damage the copper strands inside and pulling the insulation off.
    • Wires are fragile, so when stripping be sure not to snip the wires.
  6. How to fix a break in a Belkin Lightning Charger Cable, Twist the wires together: étape 6, image 1 de 1
    • Twist together the corresponding wires.
    • Be sure all wiring is bonded together.
    • Move the small heat shrinking tubes up to cover the exposed parts of the wires.
  7. Outil utilisé dans cette étape :
    Heat Gun
    $24.99
    • Evenly heat the tubing with a heat gun. Make sure the tube is properly shrinking.
    • The tubing gets hot—hold the cord at the end of each side.
  8. How to fix a break in a Belkin Lightning Charger Cable, Move the Heat-shrink tubing up: étape 9, image 1 de 1
    • Move the large heat shrinking tube up to cover the wires.
  9. How to fix a break in a Belkin Lightning Charger Cable, Heat the Heat-shrink tubing: étape 10, image 1 de 1
    Heat Gun
    $24.99
Happy fixing!
Marcus Watson
Membre depuis le 04/11/19
157 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 31
Total : 1,447
