Aller au contenu principal
How to fix a rattling window, E46 M3
Dom Santangelo
Dom Santangelo
Dernière mise à jour le May 5, 2017
30 minutes - 1 heure
Modérée
Does your door sound noisy and rattly when closing, like this? Here's how to fix it!
Ce dont vous avez besoin
Outils
Afficher plus…
Vidéo d'introduction
  1. How to fix a rattling window, E46 M3, Identify the screws: étape 1, image 1 de 1
    • The door card is held securely in place with 5 screws.
    • Keep in mind the door card has up to 3 wire bundles attached to it. Be careful when removing it! Be prepared to support it while dealing with the wires.
  2. How to fix a rattling window, E46 M3, Remove screw covers: étape 2, image 1 de 2 How to fix a rattling window, E46 M3, Remove screw covers: étape 2, image 2 de 2
    • Using a spudger, work off the cap of the first screw. The cap is tight; you may need a jimmy or metal spudger.
    • Using the flat end of a spudger, remove the airbag emblem. The emblem has clips on the top and bottom -- work carefully.
  3. How to fix a rattling window, E46 M3, Remove bolts: étape 3, image 1 de 1
    • Using a T20 Torx driver with extension, remove all 5 bolts.
  4. How to fix a rattling window, E46 M3, Remove mirror control: étape 4, image 1 de 1
    • If you're working on the driver side door, remove the mirror control module. Disconnect it from its wiring plug.
  5. How to fix a rattling window, E46 M3, Pop door card clips: étape 5, image 1 de 2 How to fix a rattling window, E46 M3, Pop door card clips: étape 5, image 2 de 2
    • Using a trim tool or similar, begin at the bottom of the door card and pop the card away from the door frame.
    • After you've released the bottom clips, work your way around.
    • You will need to lift the door card from the door frame in order to fully release it. Be careful!
    • Disconnect the following from the door panel:
    • Unlocking cable
    • Speaker cable(s)
    • Set the door panel aside.
  6. How to fix a rattling window, E46 M3, Door panel removed!: étape 7, image 1 de 1
    • The door panel is now removed.
    • You will see the airbag module, vapor barrier, and other components.
  7. How to fix a rattling window, E46 M3, Inspect the post: étape 8, image 1 de 2 How to fix a rattling window, E46 M3, Inspect the post: étape 8, image 2 de 2
    • Very gently, peel back the vapor barrier to expose the retaining bolt.
    • Roll the window up.
    • The tar-like substance used to seal the vapor barrier to the door frame WILL release itself to a gentle pull, but it is EXTREMELY sticky, and too much pulling will tear your barrier. Slow and steady is the name of the game!
    • Inspect the bolt. It is probably missing a nut!
  8. How to fix a rattling window, E46 M3, Inspect the other bolt: étape 9, image 1 de 1
    • While you're in here, inspect and tighten the bottom bolt.
  9. How to fix a rattling window, E46 M3, Find and replace!: étape 10, image 1 de 1
    • Look in the bottom of your door and locate the nut that fell off that top bolt.
    • Replace the nut onto the upper bolt and tighten.
    • In a pinch, you can use a little bit of that tarry substance to temporarily paste the nut to your fingertip in order to screw it on to the bolt.
    • Ta da! Now closing the door sounds great!
To reassemble your door, follow these instructions in reverse order.
Dom Santangelo
Membre depuis le 09/19/16
655 Réputation
3 tutoriels rédigés
1 commentaire de tutoriel
What is this bullshit? Ever think people may have both bolts there and tightened down still? Ever think other ifixit $@$* may still need to occur? And this is all you have to offer? Awesome thoroughness…
spamaccount420 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 40
Total : 9,261
