Aller au contenu principal
How to remove top vent of Winix C535
Ray
Ray et un autre contributeur
Dernière mise à jour le April 15, 2021
1 minute
Très facile
Tutoriel réalisé par la communauté
Some people might be afraid of breaking the vent to clean it up, but I got mines for free so you don't have to worry about breaking yours.
There are 4 tabs near the handle, so just use a flathead screwdriver to dig them out. Just don’t put too much force since it is made of plastic.
Ce dont vous avez besoin
  1. How to remove top vent of Winix C535, Locating the tabs: étape 1, image 1 de 1
    • I suggest starting from the middle, popping it out just a tiny bit and move outwards to the sides
    • Apply a small constant lift should make removing this easier. Similar to disassembling other plastic encasements.
  2. How to remove top vent of Winix C535, Taking it out: étape 2, image 1 de 2 How to remove top vent of Winix C535, Taking it out: étape 2, image 2 de 2
    • It pulls towards you a little bit to loosen up and then comes out by moving it forward once it's in this position.
    • Clean the vent and reassemble by inserting it from the bottom first and then clicking in the tabs in the front.
  3. How to remove top vent of Winix C535, Done: étape 3, image 1 de 1
    • Well that was easy wasn't it? Back to making it eat wildfire smoke and whatnot when the time comes.
    • Also do keep in mind that "PlasmaWave" is an ionizing tech which creates ozone in small amounts (regardless of what manufacturer says), so don't use it that often. If you do, you need to air out the room/house when the outside air is cleaner.
Ray
Membre depuis le 01/21/21
127 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 17
30 derniers jours : 54
Total : 1,688
