Huawei Media Pad M3 Lite Display Replacement
Introduction
Passez à l'étape 1Use this guide to replace a broken or defective display.
Ce dont vous avez besoin
Choose a side of the tablet to start; i took the one with the home button and heat it with the iOpener
Heat up the rest of the tablet
Put the suction handle roughly where the home button is and try to lift the display so you can slide with a pick between the display and the back cover. Be paitent it may take a while.
Take a second pick and try to get between display and the back cover
Once you are in with this pick move the pick from the middle to one of the edges
Insert another pick and move along the whole side of the tablet up to the next edge of the tablet
Same procedure as on the other sides. Take another pick and move it to the next corner of the tablet
With the tablet in standard landscape orientation lift the display to the right.
Remove one screw from the battery connector plate
Remove two screws from the display connector plate
Outil utilisé dans cette étape :Tweezers$4.99
Use a pair of tweezers to remove the battery connector plate.
Use a spudger to disconnect the battery.
Use a pair of tweezers to remove the display connector plate
Use a spudger to disconnect the display
