Aller au contenu principal
Huawei Pronto LTE Display Screen Assembly Replacement
Crystal Edwards
Crystal Edwards et 3 autres contributeurs
Dernière mise à jour le July 26, 2024
15 minutes
Modérée
Nécessite plus d'images
Étapes manquantes
The display screen is a vital part of the device. Seeing what you're doing on your phone helps to navigate each move you make in the correct order.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Huawei Pronto LTE Display Screen Assembly Replacement, Battery: étape 1, image 1 de 2 Huawei Pronto LTE Display Screen Assembly Replacement, Battery: étape 1, image 2 de 2
    • Remove the back cover of your Huawei Pronto LTE using an opening tool.
    • Lift the back cover off of the device after the four corners are unlatched.
  2. Huawei Pronto LTE Display Screen Assembly Replacement: étape 2, image 1 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: étape 2, image 2 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: étape 2, image 3 de 3
    • Remove the 15 screws on the back of the device using a Phillips #000 screwdriver.
    • Hold the device in place while you are doing this step.
    • Lift the inner cover gently by using a spudger.
  3. Huawei Pronto LTE Display Screen Assembly Replacement: étape 3, image 1 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: étape 3, image 2 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: étape 3, image 3 de 3
    • Detach the yellow latches along the sides to remove the motherboard.
  4. Huawei Pronto LTE Display Screen Assembly Replacement: étape 4, image 1 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: étape 4, image 2 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Ensure that all latches are detached and that there are no extra screws to avoid damaging the motherboard.
    • Use tweezers to gently remove the motherboard from the device.
  5. Huawei Pronto LTE Display Screen Assembly Replacement: étape 5, image 1 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: étape 5, image 2 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: étape 5, image 3 de 3
    • The battery should be revealed once the motherboard is removed.
    • Lift the battery from the top left corner.
  6. Huawei Pronto LTE Display Screen Assembly Replacement, Screen Assembly: étape 6, image 1 de 2 Huawei Pronto LTE Display Screen Assembly Replacement, Screen Assembly: étape 6, image 2 de 2
    • Remove the motherboard. Refer to the Motherboard Replacement Guide.
    • Remove the battery.
  7. Huawei Pronto LTE Display Screen Assembly Replacement: étape 7, image 1 de 2 Huawei Pronto LTE Display Screen Assembly Replacement: étape 7, image 2 de 2
    • Once the battery is removed the screen will be visible.
Crystal Edwards
Membre depuis le 09/21/18
450 Réputation
3 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 11
Total : 144
