Aller au contenu principal
Huawei S10 Tablet  USB Charge Port Replacement
Harvey
Harvey et 2 autres contributeurs
Dernière mise à jour le August 5, 2024
10 - 15 minutes
Facile
Tutoriel réalisé par la communauté
  1. Huawei S10 Tablet  USB Charge Port Replacement, SIM & Micro SD Card removal: étape 1, image 1 de 2 Huawei S10 Tablet  USB Charge Port Replacement, SIM & Micro SD Card removal: étape 1, image 2 de 2
    • Open the cover and press the SIM card and Micro SD card in to release them both.
    • Remove the screw under the hinge cover.
  2. Huawei S10 Tablet  USB Charge Port Replacement, Remove Back Cover: étape 2, image 1 de 1
    • Use a prying tool to loosen the back cover from the display.
    • There are plastic clips holding the display and back cover together, but they come apart quite easily.
  3. Huawei S10 Tablet  USB Charge Port Replacement, Remover Display Cable: étape 3, image 1 de 1
    • Carefully separate the display unit from the back cover, but not too far.
    • There is a cable connecting the two together.
    • Lift the ZIF Connector and remove the Display Cable.
    • Lay the display to one side.
  4. Huawei S10 Tablet  USB Charge Port Replacement, USB Charger Port Removal: étape 4, image 1 de 2 Huawei S10 Tablet  USB Charge Port Replacement, USB Charger Port Removal: étape 4, image 2 de 2
    • Flip the ZIF connector to loosen the flex cable for the USB charger port.
    • It is possible the cable is glued down, sliding a flat tip underneath should be enough to loosen it for removal.
    • Remove the two screws holding the charger port in place.
  5. Huawei S10 Tablet  USB Charge Port Replacement, Install New Charger Port: étape 5, image 1 de 2 Huawei S10 Tablet  USB Charge Port Replacement, Install New Charger Port: étape 5, image 2 de 2
    • Install the new charger port, Insert the cable in the ZIF connector and test to make sure it charges. Replace the screws for the USB Board
    • Insert the display into the back cover.
    • Replace the screw by the SIM card / Micro SD card slot.
    • Completed!
2 autres ont terminé cette réparation.
Harvey
Membre depuis le 02/15/16
5 865 Réputation
10 tutoriels rédigés
3 commentaires de tutoriel
Is this charger available
Doyin Nwakanma - Réponse
Charger port for Huawei s10
My s10 is not charging,if i plug it will show as if it was going to charge but it won't so what do i do in this situation
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 24
Total : 3,054
