Aller au contenu principal
IBM (Lenovo) Thinkpad X60s BIOS Battery Replacement
Ken Yeung
Ken Yeung et 4 autres contributeurs
Dernière mise à jour le June 26, 2024
15 minutes
Facile
Tutoriel réalisé par la communauté
when the battery dead you need to set the system date every time the laptop starts. They guide shows you how I fix this with $1.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
    • Just unscrew 4 screws to loose the KB, there are plenty guides / video on Google so I won't go in to details here.
  1. IBM (Lenovo) Thinkpad X60s BIOS Battery Replacement, Disconnect the battery and disassemble the connector: étape 2, image 1 de 3 IBM (Lenovo) Thinkpad X60s BIOS Battery Replacement, Disconnect the battery and disassemble the connector: étape 2, image 2 de 3 IBM (Lenovo) Thinkpad X60s BIOS Battery Replacement, Disconnect the battery and disassemble the connector: étape 2, image 3 de 3
    • Carefully disconnect the battery from the mainboard micro socket.
    • Cut the yellow plastic cover, try to cut if as half circle and KEEP it for later use.
    • The connector is soldered to the battery, use a small slot head screw driver to break the soldering slowly.
  2. IBM (Lenovo) Thinkpad X60s BIOS Battery Replacement, Replacing a new battery: étape 3, image 1 de 3 IBM (Lenovo) Thinkpad X60s BIOS Battery Replacement, Replacing a new battery: étape 3, image 2 de 3 IBM (Lenovo) Thinkpad X60s BIOS Battery Replacement, Replacing a new battery: étape 3, image 3 de 3
    • You may notice the battery is just a CR2025 cell, which costs $1
    • Transfer the blue plastic "ring" from the old battery to the new one, you can do it nicely by using a cutter. This isolation is essential to avoid the connector being short circuit
    • The metal part need to be flatten with a wire clamp or whatever can help you
  3. IBM (Lenovo) Thinkpad X60s BIOS Battery Replacement, Reconnect the battery: étape 4, image 1 de 2 IBM (Lenovo) Thinkpad X60s BIOS Battery Replacement, Reconnect the battery: étape 4, image 2 de 2
    • It is difficult to solder the cell with home equipment. I used adhesive tape to stick the metal contacts to the cell, RED wire to +ve and BLACK/WHITE wire to -ve
    • You have to avoid the metal contacts from short circuit, adhesive tapes can help you
    • I didn't have the contracting tubes that fit the cell which is 2cm diameter. Remember the cut yellow shield in step1? Use it to cover the metal parts and reconnect the battery
3 autres ont terminé cette réparation.
Ken Yeung
Membre depuis le 01/30/16
290 Réputation
2 tutoriels rédigés
Un commentaire
“there are plenty guides / video on Google so I won't go in to details here.” Really? That’s a really $@$*!& guide stating what your looking for in the beginning. :(
Maggan Ninja - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 19
30 derniers jours : 45
Total : 4,062
