Aller au contenu principal
IBM ThinkPad R40 Keyboard Keys Replacement
Erin
Erin et 6 autres contributeurs
Dernière mise à jour le May 7, 2024
Aucune estimation
Modérée
This guide will show you every step needed to ensure proper process in replacing a keyboard key for the IBM ThinkPad R40.
Ce dont vous avez besoin
Outils
  1. IBM ThinkPad R40 Keyboard Keys Replacement, Disconnection: étape 1, image 1 de 1
    • Make sure your laptop is off and disconnected from the power source to ensure safety for yourself.
  2. IBM ThinkPad R40 Keyboard Keys Replacement, Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    • Locate the key that needs replacing. Use tweezers to slowly pull the key off the keyboard. Doing this will expose the underside of the keyboard.
  3. IBM ThinkPad R40 Keyboard Keys Replacement, Set aside: étape 3, image 1 de 1
    • Step 3: Set the old key aside and have the new key ready to be inserted onto the computer. The key has three parts, which you can see here.
  4. IBM ThinkPad R40 Keyboard Keys Replacement, Moving inside: étape 4, image 1 de 1
    • The new key will have an empty slot where they key used to be. It contains a small rubber spring. After the rubber spring is inserted take the new key and line it up according to the color springs on the backside of the key along with the keyboard.
  5. IBM ThinkPad R40 Keyboard Keys Replacement, Lining up: étape 5, image 1 de 1
    • After lining the key up, the black and white pieces will line up.
  6. IBM ThinkPad R40 Keyboard Keys Replacement, Finishing up: étape 6, image 1 de 1
    • Step 6: The key should not be firmly locked into place and functioning normally.
Erin
Membre depuis le 09/08/11
231 Réputation
2 tutoriels rédigés
Équipe
University of Maine, Team 1-13, Diaz Fall 2011 Membre de l'équipe University of Maine, Team 1-13, Diaz Fall 2011
UMAINE-DIAZ-F11S1G13
1 membre
4 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 22
Total : 4,746
