Aller au contenu principal
Insignia NS-CSPBTHOL-R Power Button Replacement
Judith Villegas
Judith Villegas et 3 autres contributeurs
Dernière mise à jour le May 7, 2024
6 minutes
Facile
Is the power button no longer powering on your device? This guide will help replace the power button so you can turn your speaker on and off.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Insignia NS-CSPBTHOL-R Power Button Replacement, Battery: étape 1, image 1 de 1
    • Push the Spudger into the crevice between the grated panel of the speaker and the base of the speaker.
    • Angle the spudger to create a separation between the grate and the base.
  2. Insignia NS-CSPBTHOL-R Power Button Replacement: étape 2, image 1 de 1
    • Slide the spudger along the separation between the grate and the base of the speaker to loosen the grate. Do this to the entire perimeter of the speaker.
  3. Insignia NS-CSPBTHOL-R Power Button Replacement: étape 3, image 1 de 2 Insignia NS-CSPBTHOL-R Power Button Replacement: étape 3, image 2 de 2
    • Pull the grated panel off.
  4. Insignia NS-CSPBTHOL-R Power Button Replacement: étape 4, image 1 de 2 Insignia NS-CSPBTHOL-R Power Button Replacement: étape 4, image 2 de 2
    • Remove the six 3mm screws using the J00 JIS screw bit. This will require a long, narrow screwdriver.
  5. Insignia NS-CSPBTHOL-R Power Button Replacement: étape 5, image 1 de 2 Insignia NS-CSPBTHOL-R Power Button Replacement: étape 5, image 2 de 2
    • Push the spudger into the crevice between the base and the face of the speaker and create a separation.
    • Slide the spudger along the entire perimeter and gently pull off the face of the speaker.
    • The two parts are connected by wires, do not rip them apart.
  6. Insignia NS-CSPBTHOL-R Power Button Replacement: étape 6, image 1 de 1
    • Use the spudger to release the battery by sliding it underneath the battery to create a separation.
    • Remove the battery.
  7. Insignia NS-CSPBTHOL-R Power Button Replacement: étape 7, image 1 de 2 Insignia NS-CSPBTHOL-R Power Button Replacement: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    • Pull the motherboard from the base of the speaker.
    • Using tweezers, squeeze and pull on the white plastic clip that connects the battery wires to the motherboard.
    • Unclip the battery from the motherboard.
  8. Insignia NS-CSPBTHOL-R Power Button Replacement, Power Button: étape 8, image 1 de 3 Insignia NS-CSPBTHOL-R Power Button Replacement, Power Button: étape 8, image 2 de 3 Insignia NS-CSPBTHOL-R Power Button Replacement, Power Button: étape 8, image 3 de 3
    • Using tweezers, detach the power button from the mother board.
Judith Villegas
Membre depuis le 02/15/17
312 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 12-6, Eyestone Spring 2017 Membre de l'équipe USF Tampa, Team 12-6, Eyestone Spring 2017
USFT-EYESTONE-S17S12G6
3 membres
4 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 18
Total : 646
