Aller au contenu principal
JBL Pulse 2 Auxiliary and Micro USB Port Replacements
Emilee Hicks
Emilee Hicks et 3 autres contributeurs
Dernière mise à jour le March 3, 2024
35 minutes
Modérée
If you experience any difficulties with charging or playing music through an auxiliary cable, you may need to replace your JBL Pulse 2 speaker's auxiliary and micro USB ports.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. JBL Pulse 2 Auxiliary and Micro USB Port Replacements, Battery: étape 1, image 1 de 2 JBL Pulse 2 Auxiliary and Micro USB Port Replacements, Battery: étape 1, image 2 de 2
    • Remove the rubber rings from either end of the device.
    • If there is difficulty in lifting the rings from the device, use the metal spudger.
  2. JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 2, image 1 de 1
    • Remove the four 4.8mm Phillips #1 screws from each end of the device with the Phillips head screwdriver.
    • Lift the end pieces off of the device.
  3. JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 3, image 1 de 1
    • Remove the four 9.5mm Phillips #1 screws from each end of the device.
  4. JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 4, image 1 de 2 JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 4, image 2 de 2
    • Peel one end off and slowly draw it across the length of the device until you get to the other side.
  5. JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 5, image 1 de 3 JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 5, image 2 de 3 JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 5, image 3 de 3
    • Remove the four 7.9mm Phillips #1 screws along the black centerpiece of the device between the camera and the auxiliary port.
    • Lift up the casing and circuit board but do not try and remove the ribbon wires.
  6. JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 6, image 1 de 1
    • Remove the cover from the end that the ribbon wires are attached to. It should peel off easily.
  7. JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 7, image 1 de 2 JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 7, image 2 de 2
    • Unlatch the mechanism holding the ribbon wires in place, then disconnect them from the motherboard.
    • To access the wires, remove some of the black glue holding them in place with the spudger.
  8. JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 8, image 1 de 2 JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 8, image 2 de 2
    • Slowly pull the ribbon wires out from the outside.
    • If there is too much resistance, remove more of the black glue.
  9. JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 9, image 1 de 2 JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 9, image 2 de 2
    • Remove the four 7.9mm Phillips #1 screws around the edges of the center piece.
    • Slide the outer casing off away from the auxiliary and micro USB port.
  10. JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 10, image 1 de 1
    • Remove the other end of the device to access the wiring underneath it.
  11. JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 11, image 1 de 1
    Outil utilisé dans cette étape :
    $3.99
    • Use the angled tweezers to disconnect the battery from the motherboard. It will take some work to remove this piece.
  12. JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 12, image 1 de 1
    • Remove the four 7.9mm Phillips #1 screws from the black centerpiece of the device.
  13. JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 13, image 1 de 2 JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 13, image 2 de 2
    • Use the spudger to reach under the sides of the black centerpiece to access the six latches, three of which are on each side.
  14. JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 14, image 1 de 2 JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 14, image 2 de 2
    • Lift the black centerpiece off with the metal spudger to reveal the battery underneath.
  15. JBL Pulse 2 Auxiliary and Micro USB Port Replacements: étape 15, image 1 de 1
    • Use a hot air gun to soften the hot glue in order to fully remove the battery.
  16. JBL Pulse 2 Auxiliary and Micro USB Port Replacements, Auxiliary and Micro USB Port: étape 16, image 1 de 1
    • Remove the solder on the micro USB and Auxiliary port wires to disconnect them.
15 autres ont terminé cette réparation.
Emilee Hicks
Membre depuis le 08/31/18
803 Réputation
3 tutoriels rédigés
Équipe
8 commentaires de tutoriel
Can anyone post a link to buy the correct replacement micro USB port?
Thanks
thetjfree - Réponse
Is there a video out there to demonstrate this repair process?
a_mostafa_k - Réponse
Hallo, suche für die “JBL pulse 2” die Bauteile FB5 und D9 auf dem Mainboard.
Wer kennt diese Bauteile ?
Würde mich auf eine positive Antwort freuen.
Liebe Grüße J.R.
Roweda Johannes - Réponse
Bonjour pourriez-vous me dire ou acheter cette petite carte électronique merci.
william.avril132 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 102
Total : 14,627
