Aller au contenu principal
JBL Pulse 2 Button Circuit Board Replacement
Dalton Little
Dalton Little et 3 autres contributeurs
Dernière mise à jour le January 1, 2019
15 minutes
Facile
If you are experiencing any difficulties using the buttons on your JBL Pulse 2, you may need to replace the button circuit board.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. JBL Pulse 2 Button Circuit Board Replacement, Button Circuit Board: étape 1, image 1 de 2 JBL Pulse 2 Button Circuit Board Replacement, Button Circuit Board: étape 1, image 2 de 2
    • Remove the rubber rings from either end of the device.
    • If there is difficulty in lifting the rings from the device, use the metal spudger.
  2. JBL Pulse 2 Button Circuit Board Replacement: étape 2, image 1 de 1
    • Remove the four 4.8mm Phillips #1 screws from each end of the device with the Phillips head screwdriver.
    • Lift the end pieces off of the device.
  3. JBL Pulse 2 Button Circuit Board Replacement: étape 3, image 1 de 1
    • Remove the four 9.5mm Phillips #1 screws from each end of the device.
  4. JBL Pulse 2 Button Circuit Board Replacement: étape 4, image 1 de 2 JBL Pulse 2 Button Circuit Board Replacement: étape 4, image 2 de 2
    • Peel one end off and slowly draw it across the length of the device until you get to the other side.
  5. JBL Pulse 2 Button Circuit Board Replacement: étape 5, image 1 de 3 JBL Pulse 2 Button Circuit Board Replacement: étape 5, image 2 de 3 JBL Pulse 2 Button Circuit Board Replacement: étape 5, image 3 de 3
    • Remove the four 7.9mm Phillips #1 screws along the black centerpiece of the device between the camera and the auxiliary port.
    • Lift up the casing and circuit board but do not try and remove the ribbon wires.
  6. JBL Pulse 2 Button Circuit Board Replacement: étape 6, image 1 de 1
    • Remove the cover from the end that the ribbon wires are attached to. It should peel off easily.
  7. JBL Pulse 2 Button Circuit Board Replacement: étape 7, image 1 de 2 JBL Pulse 2 Button Circuit Board Replacement: étape 7, image 2 de 2
    • Unlatch the mechanism holding the ribbon wires in place then disconnect them from the motherboard.
    • To access the wires, remove some of the black glue holding them in place with the spudger.
  8. JBL Pulse 2 Button Circuit Board Replacement: étape 8, image 1 de 2 JBL Pulse 2 Button Circuit Board Replacement: étape 8, image 2 de 2
    • Slowly pull the ribbon wires out from the outside.
    • If there is too much resistance, remove more of the black glue.
3 autres ont terminé cette réparation.
Dalton Little
Membre depuis le 08/31/18
254 Réputation
1 tutoriel rédigé
Équipe
3 commentaires de tutoriel
where can I buy that part
Wilco Peters - Réponse
I love you guys
Davi Dodo - Réponse
I need to buy parts
hernzum - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 9
Total : 1,208
