Jawbone Big Jambox Button Circuit Board Replacement
Introduction
Passez à l'étape 1If resetting your Big Jambox does not work, these are the instructions on how to replace the button circuit board. This is a longer process because you will need to also remove the speakers.
Ce dont vous avez besoin
Remove both end caps by putting a plastic opening tool in the center of the seam. Work around the edges to pry the end caps off completely.
With the Jawbone logo facing towards you and with correct orientation, place the Jambox with the left end cap facing upward.
Unscrew indicated T6 9.7 mm screws.
Gently loosen the tabs from their anchor points so the bottom may be removed.
Flip the Jambox so the other end cap is facing up. The USB cable is on this side (metal grounding clip, indicated in orange). Repeat the above two steps.
Turn the Jambox so that the button panel is visible.
Remove the indicated screws, T6 9.6 mm.
Place the disassembled Jambox with the speakers facing up.
Locate the screws around the broken speaker.
Use a T15 screwdriver to remove the four 12.1 mm screws around the broken speaker.
Remove the two PH0, 5.8 mm screws on the small plastic black panel using a screwdriver.
3 autres ont terminé cette réparation.
