Aller au contenu principal
K-Gro PowerPro Lawnmower Drive Cable Replacement Guide
Julio Acosta
Julio Acosta et 8 autres contributeurs
Dernière mise à jour le March 28, 2020
15 - 30 minutes
Modérée
Like many push mowers, the K-Gro Power Pro has reliability issues with the motor cable and tends to become brittle over time. This guide is a step-by-step plan, on how to replace the motor cable for this mower so that you can continue to operate your mower without having to buy a brand new one.
Ce dont vous avez besoin
iFixit touche une commission lorsque vous achetez par l'intermédiaire de ces liens.
  1. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide, Drive Engagement Cable: étape 1, image 1 de 2 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide, Drive Engagement Cable: étape 1, image 2 de 2
    • Locate the throttle assembly on your mower on the right side of the push bar.
  2. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: étape 2, image 1 de 3 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: étape 2, image 2 de 3 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: étape 2, image 3 de 3
    • The throttle assembly is attached to the push bar with a 7/16" bolt and nut.
    • Using a 3/8" drive rachet wrench with a 7/16" socket and a 7/16" combination wrench, remove the nut.
    • Pull the plastic cable connection away from the framework.
  3. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: étape 3, image 1 de 2 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: étape 3, image 2 de 2
    • After disconnecting the plastic connector plate from the main body, you can see that the cable is hooked and looped around the orange handle.
    • Pull the cable towards the handle to allow the wire to become loose. This will give you enough room to remove the hook.
  4. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: étape 4, image 1 de 3 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: étape 4, image 2 de 3 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: étape 4, image 3 de 3
    • Following the cable down to the engine, you see that a zip tie holds the cable to the main handle.
    • Use a box cutter, sharp pocket knife, or cutting pliers to cut the zip tie.
    • Use gloves to prevent cutting yourself.
  5. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: étape 5, image 1 de 2 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: étape 5, image 2 de 2
    • Locate the plastic fitting hooked to the steel housing of the engine.
    • To the left of the fitting, you will see a steel sliding mechanism connected by a spring.
    • Squeeze the mechanism together to allow for slack in the cable wire.
    • You might need to use pliers or clamps in order to squeeze the plates together.
  6. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: étape 6, image 1 de 3 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: étape 6, image 2 de 3 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: étape 6, image 3 de 3
    • On close inspection of the plastic fitting, you can see that there are two "wings" that can be pinched together.
    • With the sliding mechanism squeezed and the wire slack, pinch the plastic wings together and push the fitting to the right out of the hole in the housing.
    • The loose wire can then be slid up through the groove in the steel.
  7. K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: étape 7, image 1 de 2 K-Gro PowerPro Lawnmower Drive Cable Replacement Guide: étape 7, image 2 de 2
    • You can see that the only thing still holding the cable on is a hook attached to a spring loaded lever.
    • Remove the hook.
Julio Acosta
Membre depuis le 06/09/16
125 Réputation
1 tutoriel rédigé
Équipe
Texas Tech, Team 3-6, Rauch SU 2016 Membre de l'équipe Texas Tech, Team 3-6, Rauch SU 2016
TTU-RAUCH-SU16S3G6
3 membres
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 22
Total : 1,984
