Aller au contenu principal
Kitchen Scale (CM-103/10672Z) Disassembly
Floris
Floris et 2 autres contributeurs
Dernière mise à jour le April 5, 2018
10 minutes
Modérée
This guide clearly describes how to disassemble a kitchen scale.
Ce dont vous avez besoin
Outils
  1. Kitchen Scale (CM-103/10672Z) Disassembly, Kitchen Scale (CM-103/10672Z) Disassembly: étape 1, image 1 de 2 Kitchen Scale (CM-103/10672Z) Disassembly, Kitchen Scale (CM-103/10672Z) Disassembly: étape 1, image 2 de 2
    • Remove the battery cover and batteries.
  2. Kitchen Scale (CM-103/10672Z) Disassembly: étape 2, image 1 de 1
    • Peel off the information sticker.
  3. Kitchen Scale (CM-103/10672Z) Disassembly: étape 3, image 1 de 3 Kitchen Scale (CM-103/10672Z) Disassembly: étape 3, image 2 de 3 Kitchen Scale (CM-103/10672Z) Disassembly: étape 3, image 3 de 3
    • Unscrew the ten screws (countersunk cross head 1,5 mm; 8 mm).
  4. Kitchen Scale (CM-103/10672Z) Disassembly: étape 4, image 1 de 1
    • Remove the black back cover.
  5. Kitchen Scale (CM-103/10672Z) Disassembly: étape 5, image 1 de 2 Kitchen Scale (CM-103/10672Z) Disassembly: étape 5, image 2 de 2
    • Remove the tape which holds the electrical wires in place.
  6. Kitchen Scale (CM-103/10672Z) Disassembly: étape 6, image 1 de 3 Kitchen Scale (CM-103/10672Z) Disassembly: étape 6, image 2 de 3 Kitchen Scale (CM-103/10672Z) Disassembly: étape 6, image 3 de 3
    • Push down the click fingers and slide out the feet.
  7. Kitchen Scale (CM-103/10672Z) Disassembly: étape 7, image 1 de 1
    • Remove the backlight from the screen.
  8. Kitchen Scale (CM-103/10672Z) Disassembly: étape 8, image 1 de 2 Kitchen Scale (CM-103/10672Z) Disassembly: étape 8, image 2 de 2
    • Unscrew the 5 screws from the PCB and screen (round cross head 1,5 mm; 6 mm).
  9. Kitchen Scale (CM-103/10672Z) Disassembly: étape 9, image 1 de 2 Kitchen Scale (CM-103/10672Z) Disassembly: étape 9, image 2 de 2
    • Lift out the PCB and screen.
  10. Kitchen Scale (CM-103/10672Z) Disassembly: étape 10, image 1 de 2 Kitchen Scale (CM-103/10672Z) Disassembly: étape 10, image 2 de 2
    • Pry out the PCBs which include the touch sensors (2).
  11. Kitchen Scale (CM-103/10672Z) Disassembly: étape 11, image 1 de 2 Kitchen Scale (CM-103/10672Z) Disassembly: étape 11, image 2 de 2
    • Lift out the complete electronic circuit and remove the screen and connector.
  12. Kitchen Scale (CM-103/10672Z) Disassembly: étape 12, image 1 de 3 Kitchen Scale (CM-103/10672Z) Disassembly: étape 12, image 2 de 3 Kitchen Scale (CM-103/10672Z) Disassembly: étape 12, image 3 de 3
    • Pry off the metal cover from the top of the kitchen scale.
    • Remove the glass screen cover.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 37
Total : 2,871
