Aller au contenu principal
Kodak EasyShare C913 LCD Screen Replacement
Alan Galarza
Alan Galarza et 11 autres contributeurs
Dernière mise à jour le March 20, 2025
45 minutes - 1 heure
Modérée
Étudiant en action
Texte bizarre
Problème de balise
Is the screen on your Kodak EasyShare C913's LCD screen cloudy, scratched, or displaying distorted images? This guide is made to help walk you through the process of removing the damaged screen and installing a replacement safley.
Rememeber this requirees steady hands and a moderate skill level.
There will be some tools needed to get you through this guide:
  • Small Phillips Head Screwdriver
  • Plastic Opening Tool or Spudger
  • Replacement LCD Screen (compatible with Kodak EasyShare C913)
  • Optional: antistatic wrist strap.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Kodak EasyShare C913 LCD Screen Replacement, Batteries: étape 1, image 1 de 3 Kodak EasyShare C913 LCD Screen Replacement, Batteries: étape 1, image 2 de 3 Kodak EasyShare C913 LCD Screen Replacement, Batteries: étape 1, image 3 de 3
    • Position the camera with the bottom facing up.
    • Slide the battery cover in the direction of the arrow with your finger gently.
    • Remove the batteries
  2. Kodak EasyShare C913 LCD Screen Replacement, Back Case: étape 2, image 1 de 3 Kodak EasyShare C913 LCD Screen Replacement, Back Case: étape 2, image 2 de 3 Kodak EasyShare C913 LCD Screen Replacement, Back Case: étape 2, image 3 de 3
    • Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
    • 2 on the left
    • 2 on the right
    • 3 on the bottom
  3. Kodak EasyShare C913 LCD Screen Replacement: étape 3, image 1 de 3 Kodak EasyShare C913 LCD Screen Replacement: étape 3, image 2 de 3 Kodak EasyShare C913 LCD Screen Replacement: étape 3, image 3 de 3
    • Firmly grasp the back of the camera and pull the away the casing.
  4. Kodak EasyShare C913 LCD Screen Replacement, Front Case: étape 4, image 1 de 3 Kodak EasyShare C913 LCD Screen Replacement, Front Case: étape 4, image 2 de 3 Kodak EasyShare C913 LCD Screen Replacement, Front Case: étape 4, image 3 de 3
    • Keep the battery door open
    • Firmly grasp the front casing and pull away from the camera.
  5. Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: étape 5, image 1 de 3 Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: étape 5, image 2 de 3 Kodak EasyShare C913 LCD Screen Replacement, LCD Screen: étape 5, image 3 de 3
    • Looking at the LCD casing, you should find two smaller solder joints. There will be one on either side of the camera whoch secure the casing to the circuit board. These are usually shiny and metallic points where the casing connects to the board.
    • Apply the tip of the heated smolder to the first joint to remove it. Contiune with the other side.
  6. Kodak EasyShare C913 LCD Screen Replacement: étape 6, image 1 de 3 Kodak EasyShare C913 LCD Screen Replacement: étape 6, image 2 de 3 Kodak EasyShare C913 LCD Screen Replacement: étape 6, image 3 de 3
    • Gently grasp the lower right side of LCD screen.
    • Lift the screen out of its casing.
    • Remove screw from LCD casing using screwdriver.
  7. Kodak EasyShare C913 LCD Screen Replacement: étape 7, image 1 de 3 Kodak EasyShare C913 LCD Screen Replacement: étape 7, image 2 de 3 Kodak EasyShare C913 LCD Screen Replacement: étape 7, image 3 de 3
    • Gently grab the sides of the LCD casing and remove it from the camera
  8. Kodak EasyShare C913 LCD Screen Replacement: étape 8, image 1 de 2 Kodak EasyShare C913 LCD Screen Replacement: étape 8, image 2 de 2
    • Lift the black tab with your finger
    • Gently remove ribbon from underneath black tab.
Alan Galarza
Membre depuis le 10/03/10
81 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 7-51, Amido Fall 2010 Membre de l'équipe Cal Poly, Team 7-51, Amido Fall 2010
CPSU-AMIDO-F10S7G51
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 13
Total : 4,461
