Aller au contenu principal
LERSTA Floor Lamp Screw Terminal Replacement
Ce dont vous avez besoin
  1. LERSTA Floor Lamp Screw Terminal Replacement, Screw Terminal: étape 1, image 1 de 2 LERSTA Floor Lamp Screw Terminal Replacement, Screw Terminal: étape 1, image 2 de 2
    • Unplug the lamp.
  2. LERSTA Floor Lamp Screw Terminal Replacement: étape 2, image 1 de 1
    • Rotate the bulb counterclockwise to remove the light bulb.
  3. LERSTA Floor Lamp Screw Terminal Replacement: étape 3, image 1 de 1
    • Rotate the lamp shade counterclockwise.
  4. LERSTA Floor Lamp Screw Terminal Replacement: étape 4, image 1 de 1
    • Take the three parts aside after dismantling the lamp shade.
  5. LERSTA Floor Lamp Screw Terminal Replacement: étape 5, image 1 de 1
    • Dismantle the lamp shaft by rotating it counterclockwise.
  6. LERSTA Floor Lamp Screw Terminal Replacement: étape 6, image 1 de 1
    • Use a Phillips screwdriver to remove the two 3 mm screws from the silver cover.
    • Pull down both the silver cover and the black screw terminal.
  7. LERSTA Floor Lamp Screw Terminal Replacement: étape 7, image 1 de 1
    • Separate the light bulb socket from the silver cover by pulling the silver metal hasp in right-downward direction towards the lamp shaft.
    • Exert force on the both left and right hand sides of the hasp and then pull the hasp downward.
  8. LERSTA Floor Lamp Screw Terminal Replacement: étape 8, image 1 de 1
    • Replace the old bulb socket with a newly-purchased one.
Replacing the screw terminal of the floor lamp is relatively easy, but be cautious to deal with the step of the substitution of the light socket.
[deleted]
Membre depuis le 05/09/20
157 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 12
Total : 1,186
