Aller au contenu principal
LG G3 Vigor Display Assembly Replacement
Zhong Zhen
Zhong Zhen et 3 autres contributeurs
Dernière mise à jour le May 7, 2024
20 minutes
Difficile
Nécessite plus d'images
Tutoriel étudiant vedette
Use this guide to replace the display assembly on your LG G3 Vigor.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. LG G3 Vigor Display Assembly Replacement, Rear Case: étape 1, image 1 de 1
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Display Assembly Replacement: étape 2, image 1 de 1
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Display Assembly Replacement, Battery: étape 3, image 1 de 1
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Display Assembly Replacement, Midframe: étape 4, image 1 de 1
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Display Assembly Replacement: étape 5, image 1 de 3 LG G3 Vigor Display Assembly Replacement: étape 5, image 2 de 3 LG G3 Vigor Display Assembly Replacement: étape 5, image 3 de 3
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Display Assembly Replacement, Rear Facing Camera: étape 6, image 1 de 1
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. LG G3 Vigor Display Assembly Replacement, Front Facing Camera: étape 7, image 1 de 2 LG G3 Vigor Display Assembly Replacement, Front Facing Camera: étape 7, image 2 de 2
    • Remove the front camera.
  8. LG G3 Vigor Display Assembly Replacement, Motherboard: étape 8, image 1 de 1
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. LG G3 Vigor Display Assembly Replacement: étape 9, image 1 de 2 LG G3 Vigor Display Assembly Replacement: étape 9, image 2 de 2
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
  10. LG G3 Vigor Display Assembly Replacement, Vibration Motor: étape 10, image 1 de 1
    • Use a spudger to remove the vibration motor.
    • It may have some slight adhesive, so some force may be necessary.
  11. LG G3 Vigor Display Assembly Replacement, Earpiece Speaker: étape 11, image 1 de 1
    • Remove the earpiece speaker with the metal spudger by prying it out.
  12. LG G3 Vigor Display Assembly Replacement, Headphone Jack: étape 12, image 1 de 1
    • Remove the headphone jack by inserting the spudger into the jack and pulling it up and out.
  13. LG G3 Vigor Display Assembly Replacement, Display Assembly: étape 13, image 1 de 1
    Outil utilisé dans cette étape :
    • Using tweezers peel back the glued down ribbon cable at the bottom of the phone.
  14. LG G3 Vigor Display Assembly Replacement: étape 14, image 1 de 1
    • Using a heat gun or the iFixit iOpener tool heat up the edges of the devices screen.
    • After a few minutes heating up the edges of the screen use a metal spudger tool or any other flat tool to dig under the edge of the screen.
    • Once under the edge of the screen work your way around the entire perimeter of the screen and pull the screen off.
  15. LG G3 Vigor Display Assembly Replacement: étape 15, image 1 de 1
    • Once the screen has come off pull the ribbon cables through the hole and remove the screen completely.
6 autres ont terminé cette réparation.
Zhong Zhen
Membre depuis le 02/10/16
675 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 12-5, Eyestone Spring 2016 Membre de l'équipe USF Tampa, Team 12-5, Eyestone Spring 2016
USFT-EYESTONE-S16S12G5
4 membres
5 tutoriels rédigés
2 commentaires de tutoriel
i tried to replace the glass, the phone is now stuck at boot screen. the os would load occasionally before. possible battery/water problem. are there any hardware issue that would cause the boot screen (blinking red light)
Ryan Fukushima - Réponse
Would anyone know a place to source the glass/lcd assembly. Mucho thanks!
Christopher Obidniak - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 2,223
