Aller au contenu principal
LG Optimus T Camera and Camera Mount Replacement
stacey
stacey et 2 autres contributeurs
Dernière mise à jour le May 7, 2024
25 minutes
Modérée
A besoin de meilleures images
This guide will show you step by step instructions on how to replace the camera on your LG Optimus T.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. LG Optimus T Camera and Camera Mount Replacement, Camera: étape 1, image 1 de 2 LG Optimus T Camera and Camera Mount Replacement, Camera: étape 1, image 2 de 2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down your device before you begin.
    • Use a plastic opening tool to remove the phone's back cover. At the top of the phone there are indentations to insert the spudger and pop the case off
  2. LG Optimus T Camera and Camera Mount Replacement: étape 2, image 1 de 1
    • Remove the battery by pulling up on the battery using the indentation to the left of the camera lens
  3. LG Optimus T Camera and Camera Mount Replacement: étape 3, image 1 de 1
    • Use a J0 screwdriver to remove the 6 highlighted screws
  4. LG Optimus T Camera and Camera Mount Replacement: étape 4, image 1 de 2 LG Optimus T Camera and Camera Mount Replacement: étape 4, image 2 de 2
    • Remove interior case using indentations on the top and bottom to insert the spudger to pop off the interior case
    • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic one fails
  5. LG Optimus T Camera and Camera Mount Replacement: étape 5, image 1 de 1
    • Unhook the connector tab
  6. LG Optimus T Camera and Camera Mount Replacement: étape 6, image 1 de 1
    • Remove SD card mount by inserting the plastic opening tool on the right side of the device to pop mount off
  7. LG Optimus T Camera and Camera Mount Replacement: étape 7, image 1 de 2 LG Optimus T Camera and Camera Mount Replacement: étape 7, image 2 de 2
    • Remove metal panel by inserting plastic opening tool into the four retaining points and remove panel
  8. LG Optimus T Camera and Camera Mount Replacement: étape 8, image 1 de 1
    Outil utilisé dans cette étape :
    • disconnect camera connector from motherboard by spudger
    • Once disconnected, remove camera using tweezers
stacey
Membre depuis le 02/07/17
219 Réputation
2 tutoriels rédigés
Équipe
Ohio State, Team 1-3, Wilder Spring 2017 Membre de l'équipe Ohio State, Team 1-3, Wilder Spring 2017
OSU-WILDER-S17S1G3
4 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 18
Total : 145
