Aller au contenu principal
LeapFrog LeapPad 32400 Screen Replacement
Aubra Sharp
Aubra Sharp et 2 autres contributeurs
Dernière mise à jour le June 2, 2023
10 - 15 minutes
Modérée
The LeapFrog LeapPad 32400 has a large front screen which may break or not function properly requiring it to be replaced.
In this guide you will be replacing the screen component for this device. To do this you will be working on both the front and internal components. Caution is to be used when pulling out the screen as it is quite easy to damage or break the outer covering.
Check the troubleshooting page for symptoms to make sure this guide is the best route: LeapFrog LeapPad #32400 Troubleshooting Page
Ce dont vous avez besoin
Outils
Afficher plus…
  1. LeapFrog LeapPad 32400 Screen Replacement, Battery: étape 1, image 1 de 2 LeapFrog LeapPad 32400 Screen Replacement, Battery: étape 1, image 2 de 2
    • Turn the tablet so the back is facing up.
    • Remove the battery covers by sliding the covers towards the sides and away from the center of the device.
  2. LeapFrog LeapPad 32400 Screen Replacement: étape 2, image 1 de 1
    • Take out the AA batteries from both battery compartments of the device.
    • Replace batteries as needed.
  3. LeapFrog LeapPad 32400 Screen Replacement, Back Panel: étape 3, image 1 de 1
    • Remove three 7 mm screws using a Phillips #1 screwdriver.
    • Remove the single 6 mm screw using a Phillips #1 screwdriver.
    • Remove the single 10 mm screw using a Phillips #1 screwdriver.
  4. LeapFrog LeapPad 32400 Screen Replacement: étape 4, image 1 de 3 LeapFrog LeapPad 32400 Screen Replacement: étape 4, image 2 de 3 LeapFrog LeapPad 32400 Screen Replacement: étape 4, image 3 de 3
    • Use a small plastic opening tool to separate the colored front cover from the white rear cover of the device.
    • With one hand on the front cover and one hand on the rear cover, start from the bottom of the device and pull the pieces apart.
    • Once only the top edge remains connected, pull the rear cover backwards away from the front cover and upwards towards the top of the device. This should release the last remaining tabs holding the pieces front and rear cover together.
    • The most stubborn tabs holding the front and rear together are along the top edge of the tablet around the game cartridge slot. This will most likely be the last area that separates, and it may require a moderate amount of force.
  5. LeapFrog LeapPad 32400 Screen Replacement: étape 5, image 1 de 3 LeapFrog LeapPad 32400 Screen Replacement: étape 5, image 2 de 3 LeapFrog LeapPad 32400 Screen Replacement: étape 5, image 3 de 3
    • Separate the motherboard from the back side of the device by detaching the black and red wire connection from the back cover.
    • The two pieces that hold the pen in place will become loose. Remove and set aside for reassembly.
  6. LeapFrog LeapPad 32400 Screen Replacement, Motherboard: étape 6, image 1 de 3 LeapFrog LeapPad 32400 Screen Replacement, Motherboard: étape 6, image 2 de 3 LeapFrog LeapPad 32400 Screen Replacement, Motherboard: étape 6, image 3 de 3
    • Remove the single 10 mm screw from the device using a Phillips #1 screwdriver.
    • Remove the single 7 mm screw from the device using a Phillips #1 screwdriver.
  7. LeapFrog LeapPad 32400 Screen Replacement: étape 7, image 1 de 3 LeapFrog LeapPad 32400 Screen Replacement: étape 7, image 2 de 3 LeapFrog LeapPad 32400 Screen Replacement: étape 7, image 3 de 3
    • Unlatch the two battery terminals using a nylon spudger.
  8. LeapFrog LeapPad 32400 Screen Replacement: étape 8, image 1 de 2 LeapFrog LeapPad 32400 Screen Replacement: étape 8, image 2 de 2
  9. LeapFrog LeapPad 32400 Screen Replacement: étape 9, image 1 de 3 LeapFrog LeapPad 32400 Screen Replacement: étape 9, image 2 de 3 LeapFrog LeapPad 32400 Screen Replacement: étape 9, image 3 de 3
    • Gently lift the motherboard away from the back cover.
    • Peel back the tape on the display ribbon cable connector.
    • Gently pull on the display ribbon cable and it should easily slide out of the connecter.
    • If the connector is properly open, disconnecting the ribbon cable should require little to no force.
  10. LeapFrog LeapPad 32400 Screen Replacement, Screen: étape 10, image 1 de 2 LeapFrog LeapPad 32400 Screen Replacement, Screen: étape 10, image 2 de 2
    • Remove the single 8 mm screw from the device using a Phillips #1 screwdriver.
  11. LeapFrog LeapPad 32400 Screen Replacement: étape 11, image 1 de 3 LeapFrog LeapPad 32400 Screen Replacement: étape 11, image 2 de 3 LeapFrog LeapPad 32400 Screen Replacement: étape 11, image 3 de 3
    • Flip the front cover over so the front screen is visible.
    • Using an iFixit opening tool, pry off the front black plastic border. Start from the bottom of the black border near the large center button, then make your way around.
    • Only three of the four sides of the black border have to be removed from the white front cover in order to remove the screen.
    • Remove the screen from the device.
Aubra Sharp
Membre depuis le 03/01/23
457 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 117
