Aller au contenu principal
Lenovo IdeaPad S10-2 Keyboard Replacement
Mary
Mary et 5 autres contributeurs
Dernière mise à jour le January 10, 2025
Aucune estimation
Modérée
Replacing the keyboard on your laptop can be necessary if your keyboard is no longer responding. You will need a nylon or metal spudger. Make sure that the power is off before continuing.
Ce dont vous avez besoin
Outils
  • Spudger
    Spudger
  1. Lenovo IdeaPad S10-2 Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Rotate the laptop so the back side is facing you.
    • From this side, you should be able to see both of the gaps where the two plastic materials meet.
  2. Lenovo IdeaPad S10-2 Keyboard Replacement: étape 2, image 1 de 2 Lenovo IdeaPad S10-2 Keyboard Replacement: étape 2, image 2 de 2
    • Wedge the nylon or metal spudger inside the gap and pry open the two plastic parts.
  3. Lenovo IdeaPad S10-2 Keyboard Replacement: étape 3, image 1 de 2 Lenovo IdeaPad S10-2 Keyboard Replacement: étape 3, image 2 de 2
    • Open the laptop.
    • Place the nylon or metal spudger under the top half that is loose and pull up to pry it open.
  4. Lenovo IdeaPad S10-2 Keyboard Replacement: étape 4, image 1 de 3 Lenovo IdeaPad S10-2 Keyboard Replacement: étape 4, image 2 de 3 Lenovo IdeaPad S10-2 Keyboard Replacement: étape 4, image 3 de 3
    • Pull up on the loose component to remove.
    • As you lift the keyboard, you should be able to see a strip connected to the laptop.
  5. Lenovo IdeaPad S10-2 Keyboard Replacement: étape 5, image 1 de 3 Lenovo IdeaPad S10-2 Keyboard Replacement: étape 5, image 2 de 3 Lenovo IdeaPad S10-2 Keyboard Replacement: étape 5, image 3 de 3
    • Remove the strip by pulling both sides of the blue strip out.
    • Lift and remove the keyboard from the laptop.
2 autres ont terminé cette réparation.
Mary
Membre depuis le 10/13/15
132 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team 1-7, Blackburne Fall 2015 Membre de l'équipe Sam Houston State, Team 1-7, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S1G7
4 membres
5 tutoriels rédigés
Un commentaire
Thanks! Just be careful when inserting the keyboard strips back into it's socket: that socket has retainer that needs to be released before inserting the strip. It is highlighted with different color, maybe brown. To release the strip pull the retainer in the same direction as when pulling out the keyboard strip, but do it before pulling that strip, so the strip will be released easily and can be inserted back when needed. Then push the retainer back...
Roman Vasylenko - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 21
30 derniers jours : 25
Total : 3,318
