Lenovo IdeaPad Yoga 13 WiFi Module Replacement
Introduction
Passez à l'étape 1The WiFi module is the primary method for wireless network connectivity. If this module shows symptoms of malfunction, a USB-to-Ethernet cable adapter can be used to maintain network access until the module is replaced.
Ce dont vous avez besoin
Locate the ribbon cable connecting the keyboard to the motherboard.
Use the tip of the opening tool to lift the black flap on the connector.
With the twezers, gently lift the ribbon cable out of the connector.
Ensure the cutouts on the end of the cable match the tabs on the connector.
Locate and remove the screws holding the bezel to the laptop body:
Two 3 mm Phillips screws
Three 5.5 mm Phillips screws
Outil utilisé dans cette étape :Tweezers$4.99
Using the tweezers, unplug the gray and black antennae cables.
11 autres ont terminé cette réparation.
4 commentaires
I need to replace the wifi card in one of these laptops and I’d like to get a different brand. What is this form factor called?
I have the same issue. Couldn’t find anything on the internet. My BT is defective, because it sometimes disables my mouse. This computer was a beautiful and well build, with the great touchscreen, but wireless connections are total mistake from the early beginning. The integrated wifi likes not to find any network. Since 2019 I’m working with the usb WiFi module bought on aliexpress. It is far better than the installed, but sticks out the chassis and took one port.
