Aller au contenu principal
Lenovo ThinkPad T400s LCD Screen Replacement
Christopher Noone
Christopher Noone et 4 autres contributeurs
Dernière mise à jour le April 10, 2025
15 minutes
Facile
The LCD screen and its peripherals are very sensitive and mishandling may result in a missing dot, line, or pixel problems. To ensure that no damage is done to the LCD screen:
  • Don't apply pressure to the LCD
  • Always hold the LCD from the right and left edges
  • Don't apply any pressure to the lower part of the LCD
Ce dont vous avez besoin
Outils
  1. Lenovo ThinkPad T400s LCD Screen Replacement, LCD Screen: étape 1, image 1 de 1
    • Use a #0 Phillips head screwdriver to remove the two 3mm screws that hold the screen bezel in place.
  2. Lenovo ThinkPad T400s LCD Screen Replacement: étape 2, image 1 de 1
    • Using the plastic opening tool, gently pry off the plastic LCD screen frame around the entire perimeter.
    • Be careful while prying the frame off, because the plastic tabs that hold it in may break.
  3. Lenovo ThinkPad T400s LCD Screen Replacement: étape 3, image 1 de 2 Lenovo ThinkPad T400s LCD Screen Replacement: étape 3, image 2 de 2
    • Remove the LCD connector by pulling on the ribbon cable at the connection.
  4. Lenovo ThinkPad T400s LCD Screen Replacement: étape 4, image 1 de 1
    • Lift the LCD screen out to replace.
    • Make sure to remove the screen with both hands and from opposite edges of the screen.
7 autres ont terminé cette réparation.
Christopher Noone
Membre depuis le 04/14/15
235 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 6-18, Maness Spring 2015 Membre de l'équipe Cal Poly, Team 6-18, Maness Spring 2015
CPSU-MANESS-S15S6G18
4 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 43
Total : 2,738
