Aller au contenu principal
Lenovo ThinkPad T440p Hard Drive Replacement
Christian Abad
Christian Abad et 2 autres contributeurs
Dernière mise à jour le January 22, 2020
4 minutes
Modérée
The hard drive is primarily used for the Lenovo ThinkPad T440p’s storage. If your computer is slow, it most likely needs replacing. The replacement is simple and will only require unscrewing screws and using a spudger to lift the hard drive out.
Ce dont vous avez besoin
Kits de réparation
Ces kits contiennent toutes les pièces et tous les outils nécessaires à la réalisation du tutoriel.
Pièces
Outils
Afficher plus…
  1. Lenovo ThinkPad T440p Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop so that the back is facing up.
  2. Lenovo ThinkPad T440p Hard Drive Replacement: étape 2, image 1 de 2 Lenovo ThinkPad T440p Hard Drive Replacement: étape 2, image 2 de 2
    • Slide the battery latches to the unlocked position.
  3. Lenovo ThinkPad T440p Hard Drive Replacement: étape 3, image 1 de 2 Lenovo ThinkPad T440p Hard Drive Replacement: étape 3, image 2 de 2
    • Slide the battery pack out of the battery slot.
  4. Lenovo ThinkPad T440p Hard Drive Replacement, Back Cover: étape 4, image 1 de 2 Lenovo ThinkPad T440p Hard Drive Replacement, Back Cover: étape 4, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the two 8mm screws holding the back cover.
  5. Lenovo ThinkPad T440p Hard Drive Replacement: étape 5, image 1 de 1
    • Slide down the back cover.
  6. Lenovo ThinkPad T440p Hard Drive Replacement: étape 6, image 1 de 1
    • Remove the back cover.
  7. Lenovo ThinkPad T440p Hard Drive Replacement, Hard Drive: étape 7, image 1 de 1
    • Use a Phillips #0 screwdriver to remove one screw holding the hard drive.
  8. Lenovo ThinkPad T440p Hard Drive Replacement: étape 8, image 1 de 2 Lenovo ThinkPad T440p Hard Drive Replacement: étape 8, image 2 de 2
    • Place the spudger underneath the hard drive mount and lift it up.
  9. Lenovo ThinkPad T440p Hard Drive Replacement: étape 9, image 1 de 2 Lenovo ThinkPad T440p Hard Drive Replacement: étape 9, image 2 de 2
    • Remove the hard drive.
  10. Lenovo ThinkPad T440p Hard Drive Replacement: étape 10, image 1 de 2 Lenovo ThinkPad T440p Hard Drive Replacement: étape 10, image 2 de 2
    • Remove the hard drive from the plastic mount.
9 autres ont terminé cette réparation.
Christian Abad
Membre depuis le 03/20/19
1 530 Réputation
7 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G5, Peak Spring 2019 Membre de l'équipe UMass Dartmouth, Team S6-G5, Peak Spring 2019
UMASSD-PEAK-S19S6G5
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 32
30 derniers jours : 78
Total : 8,260
