Aller au contenu principal
Lenovo ThinkPad T480 SSD Replacement
Dane Elliott-Dyson
Dane Elliott-Dyson et 3 autres contributeurs
Dernière mise à jour le September 23, 2024
10 - 15 minutes
Modérée
Tutoriel réalisé par la communauté
This guide will show you how to replace the SSD on your Lenovo Thinkpad T480 laptop. Backup your data before replacing if possible.
  1. Lenovo ThinkPad T480 SSD Replacement, SSD: étape 1, image 1 de 1
  2. Lenovo ThinkPad T480 SSD Replacement: étape 2, image 1 de 2 Lenovo ThinkPad T480 SSD Replacement: étape 2, image 2 de 2
    • Push Clip 1 to the side. While holding Clip 2 to the side, push the battery out of the laptop.
  3. Lenovo ThinkPad T480 SSD Replacement: étape 3, image 1 de 1
    • Remove all Phillip-head screws shown.
    • The screws will not come out of the casing, so unscrew them all the way until they don’t go any higher.
  4. Lenovo ThinkPad T480 SSD Replacement: étape 4, image 1 de 1
    • Pry up on the casing using a spudger or a flat-head screwdriver and remove the back.
  5. Lenovo ThinkPad T480 SSD Replacement: étape 5, image 1 de 3 Lenovo ThinkPad T480 SSD Replacement: étape 5, image 2 de 3 Lenovo ThinkPad T480 SSD Replacement: étape 5, image 3 de 3
    • Pry up on the little metal bar on the connector and pull the connector out of its socket.
  6. Lenovo ThinkPad T480 SSD Replacement: étape 6, image 1 de 3 Lenovo ThinkPad T480 SSD Replacement: étape 6, image 2 de 3 Lenovo ThinkPad T480 SSD Replacement: étape 6, image 3 de 3
    • Pry up on the left side of the SSD casing. Pull the casing to the left, and remove.
  7. Lenovo ThinkPad T480 SSD Replacement: étape 7, image 1 de 2 Lenovo ThinkPad T480 SSD Replacement: étape 7, image 2 de 2
    • Remove the following 4mm Phillip-head screws and remove the plate.
  8. Lenovo ThinkPad T480 SSD Replacement: étape 8, image 1 de 3 Lenovo ThinkPad T480 SSD Replacement: étape 8, image 2 de 3 Lenovo ThinkPad T480 SSD Replacement: étape 8, image 3 de 3
    • Remove the 4mm Phillip-head screw and pull the SSD out of its socket.
4 autres ont terminé cette réparation.
Dane Elliott-Dyson
Membre depuis le 11/06/23
618 Réputation
2 tutoriels rédigés
1 commentaire de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 85
30 derniers jours : 449
Total : 6,374
