Lenovo ThinkPad X1 Carbon 7th Gen Daughterboard Replacement
Introduction
Passez à l'étape 1This guide will show you how to replace the daughterboard in your Lenovo ThinkPad X1 Carbon 7th Generation laptop. The daughterboard is home to the right-side USB port, so if this port goes bad, a daughterboard replacement will likely alleviate the issue.
Ce dont vous avez besoin
Use a Phillips #1 screwdriver to loosen the five captive screws securing the back cover.
Insert an opening pick at a 45˚ angle between the back cover and frame near the rear middle screw.
Pry up on the pick to release the clips securing the back cover to the frame.
Use a Phillips #0 screwdriver to remove the six 4.9 mm-long screws securing the battery.
Remove the two 1.3 mm screws with a Phillips #0 screwdriver.
Disconnect the interconnect cable from the motherboard by flipping up the locking lever and pulling out the ribbon cable.
