Introduction
If your battery has failed or is no longer reaching your needs, you may need to replace your laptop's internal battery.
Ce dont vous avez besoin
Unscrew the 8 screws holding the back panel in place.
Use a plastic prying tool to release all the clips holding the panel in place.
Disconnect the second battery. Next, unscrew the three screws and remove the battery.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 autres ont terminé cette réparation.
