Aller au contenu principal
Lenovo ThinkPad X280 Battery Replacement
Haley Curry
Haley Curry et 5 autres contributeurs
Dernière mise à jour le December 8, 2022
25 - 35 minutes
Modérée
This replacement guide will inform users how to properly remove the battery, located on the bottom center of the Lenovo ThinkPad X280 inside the back panel of the device.
The battery is used to power on and off the device.
If you are experiencing poor battery life, a battery overheating, and/or an inability to connect to Bluetooth or WIFI networks, your device may need a battery replacement.
Removing the battery will completely shut down the device and prevent it from working properly. It is important to note that removing a battery while it’s too hot can induce injury or spark a flame. To prevent injury, allow your device to cool down before removing the battery from the device and store it in an appropriate place. For more information on how to store it, you can review this guide.
Ce dont vous avez besoin
Kit de réparation
Ce kit contient toutes les pièces et tous les outils nécessaires à la réalisation de ce tutoriel.
Pièces
Outils
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
Afficher plus…
  1. Lenovo ThinkPad X280 Battery Replacement, Back Panel: étape 1, image 1 de 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 Battery Replacement: étape 2, image 1 de 2 Lenovo ThinkPad X280 Battery Replacement: étape 2, image 2 de 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 Battery Replacement: étape 3, image 1 de 2 Lenovo ThinkPad X280 Battery Replacement: étape 3, image 2 de 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 Battery Replacement, Battery: étape 4, image 1 de 3 Lenovo ThinkPad X280 Battery Replacement, Battery: étape 4, image 2 de 3 Lenovo ThinkPad X280 Battery Replacement, Battery: étape 4, image 3 de 3
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
8 autres ont terminé cette réparation.
Haley Curry
Membre depuis le 09/03/21
491 Réputation
2 tutoriels rédigés
Équipe
University of Alabama, Team 1-3, Bedsole Fall 2021 Membre de l'équipe University of Alabama, Team 1-3, Bedsole Fall 2021
UA-BEDSOLE-F21S1G3
4 membres
6 tutoriels rédigés
2 commentaires
but what about the batteries connection to the mobo?
edit: nvm, i assumed it was a cable not just a connector
Matthew Gould - Réponse
I'll chime in with Matthew Gould:
The last step, "Remove the battery", could stand expansion. It took me some time to figure out that the edge of the battery with the connector simply lifts up rather than sliding out toward the user (fixer? repairer?). One more picture showing that action would help.
The rest of the process, including purchasing the battery from ifixit, was like butter.
Having said that, I am so thankful for ifixit!
Andrew Rinehart - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 53
30 derniers jours : 143
Total : 8,993
