Aller au contenu principal
Lenovo ThinkPad X280 CMOS Battery Replacement
Hannah Bryn Cullen
Hannah Bryn Cullen et 3 autres contributeurs
Dernière mise à jour le May 7, 2024
50 minutes
Modérée
This will take approximately 50 minutes to complete from beginning to end.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Lenovo ThinkPad X280 CMOS Battery Replacement, Back Panel: étape 1, image 1 de 1
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
  2. Lenovo ThinkPad X280 CMOS Battery Replacement: étape 2, image 1 de 2 Lenovo ThinkPad X280 CMOS Battery Replacement: étape 2, image 2 de 2
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
  3. Lenovo ThinkPad X280 CMOS Battery Replacement: étape 3, image 1 de 2 Lenovo ThinkPad X280 CMOS Battery Replacement: étape 3, image 2 de 2
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
  4. Lenovo ThinkPad X280 CMOS Battery Replacement, Battery: étape 4, image 1 de 3 Lenovo ThinkPad X280 CMOS Battery Replacement, Battery: étape 4, image 2 de 3 Lenovo ThinkPad X280 CMOS Battery Replacement, Battery: étape 4, image 3 de 3
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
  5. Lenovo ThinkPad X280 CMOS Battery Replacement, CMOS Battery: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    • Use tweezers to gently unplug the CMOS Battery from the port on the right side.
  6. Lenovo ThinkPad X280 CMOS Battery Replacement: étape 6, image 1 de 1
    • Work the wire out from its holding brackets and is now free to be removed.
3 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 47
30 derniers jours : 171
Total : 4,001
