Aller au contenu principal
Lenovo ThinkPad X390 Yoga Fan Replacement
Drew Mercier
Drew Mercier et 4 autres contributeurs
Dernière mise à jour le April 12, 2024
20 - 45 minutes
Modérée
Photos d’action
A besoin de meilleures images
Nécessite plus d'images
Meilleure introduction
This guide will demonstrate how to remove and replace the fan and heat sink in the Lenovo ThinkPad X390 Yoga.
Before starting this guide, power off the laptop and unplug it from the charging cord.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Lenovo ThinkPad X390 Yoga Fan Replacement, Back Case: étape 1, image 1 de 1
    • Safety Procedures:
    • Shutdown and Disable Power Supply: 1. Disconnect adapter. 2. Press F1 key to enter BIOS setup powering up Laptop. 3. Go to Configuration menu. 4. Select Power and press Enter. 5. Highlight Disable Built-in Battery and press Enter. 6. Confirm by selecting "Yes" and pressing Enter. 7. System will power down, and disabled battery.
    • Electrostatic Discharge (ESD) Safety: 1. Ground yourself to prevent static damage by wearing an ESD wrist strap or touching a grounded metal surface.
    • Remove the SIM Card Tray 1. Insert a straightened paperclip into the hole on the SIM card tray. 2. Gently push to eject and remove the tray.
    • Use a Phillips #1 screwdriver to unscrew the captive screws from the back of the device. The screws should not be removed from the back panel, so don't try to force them out.
    • Disassemble the Laptop: Remove the Bottom Cover and Battery: 1. Loosen five captive screws on bottom of laptop. 2. Use a non-metallic pry tool to carefully loosen clips along the rear cover. 3. Lift and remove bottom cover. 4. Disconnect internal battery cable from system board. 5. Remove five screws securing the battery and lift it out of system.
  2. Lenovo ThinkPad X390 Yoga Fan Replacement: étape 2, image 1 de 1
    • Use the iFixit opening tool to remove the back case by entering the tip of the tool into the seam and prying up.
    • This can be tough so take your time to undo the clips around the perimeter before removing the back cover.
    • Disconnect Screen Cables: 1. Disconnect the LED camera cable and remove it from its guide. 2. Remove the antenna cables from their guides. 3. Disconnect the LCD cable and remove it from its guide. 4. Remove the Antenna Cables from the guide which is next to LCD cable. 5. Remove three screws from each hinge.
  3. Lenovo ThinkPad X390 Yoga Fan Replacement: étape 3, image 1 de 1
    • Once the back cover is no longer attached carefully remove it by lifting straight up.
  4. Lenovo ThinkPad X390 Yoga Fan Replacement, Fan: étape 4, image 1 de 1
    • Disconnect the fan connector from the moetherboard with a spudger or opening tool.
  5. Lenovo ThinkPad X390 Yoga Fan Replacement: étape 5, image 1 de 1
    • Loosen the seven screws surrounding the fan and heatsink using the Phillips #1 screwdriver.
  6. Lenovo ThinkPad X390 Yoga Fan Replacement: étape 6, image 1 de 1
    • Carefully remove the fan from the laptop by lifting it up and off the frame.
Drew Mercier
Membre depuis le 09/08/21
97 Réputation
1 tutoriel rédigé
Équipe
University of Alabama, Team 1-2, Bedsole Fall 2021 Membre de l'équipe University of Alabama, Team 1-2, Bedsole Fall 2021
UA-BEDSOLE-F21S1G2
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 30
Total : 654
