Aller au contenu principal
Lenovo Thinkpad X220 HDD Replacement
alphaLONE
alphaLONE et 3 autres contributeurs
Dernière mise à jour le May 20, 2019
5 minutes
Facile
Tutoriel réalisé par la communauté
Here, I'll replace the hard disk of my ThinkPad X220 in a few steps.
Ce dont vous avez besoin
  1. Lenovo Thinkpad X220 HDD Replacement, HDD: étape 1, image 1 de 1
    • Put the laptop upside down.
  2. Lenovo Thinkpad X220 HDD Replacement: étape 2, image 1 de 2 Lenovo Thinkpad X220 HDD Replacement: étape 2, image 2 de 2
    • Unscrew the HDD slot cover.
  3. Lenovo Thinkpad X220 HDD Replacement: étape 3, image 1 de 2 Lenovo Thinkpad X220 HDD Replacement: étape 3, image 2 de 2
    • You will arrive to something like this.
    • Pull the black tab popping out to remove the HDD from its tray.
    • The little black tab can be fragile. I recommend you to put tape on it when you have removed the HDD from the bracket to make it tougher.
  4. Lenovo Thinkpad X220 HDD Replacement: étape 4, image 1 de 2 Lenovo Thinkpad X220 HDD Replacement: étape 4, image 2 de 2
    • Congratulations! You got the HDD out of the laptop. We can now put the laptop somewhere else and focus on the HDD.
    • On each long side of the HDD, two rubber bands are located. Pull them to remove them and access to the screws.
  5. Lenovo Thinkpad X220 HDD Replacement: étape 5, image 1 de 1
    • Unscrew the 4 screws located on the two long sides of the drives...
    • ...and push the HDD outside from its retention bracket.
  6. Lenovo Thinkpad X220 HDD Replacement: étape 6, image 1 de 1
    • You're done! To reassemble, place a new drive in the bracket and follow the steps in the reverse order.
14 autres ont terminé cette réparation.
alphaLONE
Membre depuis le 07/01/11
954 Réputation
3 tutoriels rédigés
5 commentaires
I just hope that a 64 year old crazy cat lady can do this without blowing up the galaxy
Bobbi Johnson - Réponse
What size drives will fit?
Dan - Réponse
7mm thick, no more. (I tried with a thicker HyperX 240gb drive but it was too big, wouldn’t fit)
alphaLONE -
eine feine Anleitung. Bravo!
Leitner Josef - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 23
30 derniers jours : 69
Total : 16,706
