Aller au contenu principal
Lenovo Yoga 3 11 SSD Replacement
Geoff Wacker
Geoff Wacker et un autre contributeur
Dernière mise à jour le May 7, 2024
Aucune estimation
Modérée
Nécessite plus d'images
Photos d’action
Use this guide to replace the SSD in your Lenovo Yoga 3 11.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Lenovo Yoga 3 11 SSD Replacement, Lower Case: étape 1, image 1 de 1
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 SSD Replacement, Battery: étape 2, image 1 de 3 Lenovo Yoga 3 11 SSD Replacement, Battery: étape 2, image 2 de 3 Lenovo Yoga 3 11 SSD Replacement, Battery: étape 2, image 3 de 3
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 SSD Replacement: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 SSD Replacement: étape 4, image 1 de 2 Lenovo Yoga 3 11 SSD Replacement: étape 4, image 2 de 2
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 SSD Replacement: étape 5, image 1 de 1
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 SSD Replacement, SSD: étape 6, image 1 de 1
    • Use a pair of tweezers to disconnect the motherboard-size of the trackpad ribbon cable. Gently lift up the black tab, and the cable should come free from the ZIF connector.
  7. Lenovo Yoga 3 11 SSD Replacement: étape 7, image 1 de 1
    • Use a pair of tweezers to disconnect the keyboard ribbon cable from the motherboard ZIF connector. Gently lift up the white tab, and the cable should come free.
  8. Lenovo Yoga 3 11 SSD Replacement: étape 8, image 1 de 1
    • Use a pair of tweezers to disconnect the motherboard-side of the SD board ribbon cable. Gently lift up the black tab, and then ribbon cable should come free from the ZIF connector.
  9. Lenovo Yoga 3 11 SSD Replacement: étape 9, image 1 de 1
    • Use the tweezers to unplug the USB port from the motherboard by gently lifting the white connector up from the black motherboard connector.
  10. Lenovo Yoga 3 11 SSD Replacement: étape 10, image 1 de 1
    • Use a plastic opening tool to gently pry up the screen cable from the motherboard.
  11. Lenovo Yoga 3 11 SSD Replacement: étape 11, image 1 de 2 Lenovo Yoga 3 11 SSD Replacement: étape 11, image 2 de 2
    • Remove the single 2 mm Phillips #00 screw securing the SSD.
    • Gently lift the SSD up and out of the device.
Geoff Wacker
Membre depuis le 09/30/13
91 231 Réputation
89 tutoriels rédigés
4 commentaires de tutoriel
Perché non posso passare direttamente dallo step 2 allo step 11 ?
Keyman - Réponse
Same(ish) question as Keyman: why not steps 1, possibly 3, then 11? Why disconnect everything if the SSD is fully exposed when the bottom comes off?
ifaxit - Réponse
Basta infatti scollegare la batteria per evitare eventuali ritorni di massa prima di sostituire l'ssd
IRREAL - Réponse
he thought that was ram and drilled further to find the ssd perhaps.
furterers - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 24
Total : 10,133
