Logitech Harmony 650 Screen Replacement
Introduction
Passez à l'étape 1It is recommended that you have the iFixit ProTech toolkit and have already taken out the motherboard and taken apart the case.
Ce dont vous avez besoin
Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
Outil utilisé dans cette étape :Flathead 3/32" or 2.5 mm Screwdriver$5.49
Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
Using a J0 screwdriver remove the three 5mm screws holding the motherboard to the front face. Two are located just below the processor in the middle of the device and the third is located at the very bottom.
Remove the black rubber gasket that surrounds the screen from the top face of the motherboard.
The gasket has 3 tabs along each side. The thick side of the gasket faces the top.
4 autres ont terminé cette réparation.
2 commentaires de tutoriel
Hey will beat buy honor a warrenty
so where can i buy the screen!!!!
