Aller au contenu principal
Logitech K345 On/Off Button Replacement
Aumirius Robinson
Aumirius Robinson et 4 autres contributeurs
Dernière mise à jour le March 6, 2025
10 minutes
Facile
Étudiant en action
Meilleure introduction
If your Logitech K345 keyboard's on/off switch is no longer functioning properly—whether it's stuck, unresponsive, or malfunctioning—this guide will walk you through the process of replacing it.
You’ll need a Phillips #0 screwdriver, iFixit opening picks, and a Jimmy tool to complete the replacement. Be sure to have a new, compatible on/off switch for the Logitech K345 before you begin.
Before starting, make sure to power off your keyboard and disconnect it from any power source during the repair.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Logitech K345 On/Off Button Replacement, Membrane: étape 1, image 1 de 1
    • Remove the thirteen 5.3 mm screws from the back of the keyboard using a Phillips #0 screwdriver.
  2. Logitech K345 On/Off Button Replacement: étape 2, image 1 de 2 Logitech K345 On/Off Button Replacement: étape 2, image 2 de 2
    • Pry up the corner rubber pads using a Jimmy.
  3. Logitech K345 On/Off Button Replacement: étape 3, image 1 de 2 Logitech K345 On/Off Button Replacement: étape 3, image 2 de 2
    • Remove the two 5.3 mm screws from the corners with a Phillips #0 screwdriver.
  4. Logitech K345 On/Off Button Replacement: étape 4, image 1 de 2 Logitech K345 On/Off Button Replacement: étape 4, image 2 de 2
    • Use your hands and opening picks to remove the back of the keyboard.
  5. Logitech K345 On/Off Button Replacement: étape 5, image 1 de 3 Logitech K345 On/Off Button Replacement: étape 5, image 2 de 3 Logitech K345 On/Off Button Replacement: étape 5, image 3 de 3
    • Remove the keyboard membrane.
  6. Logitech K345 On/Off Button Replacement, On/Off Button: étape 6, image 1 de 2 Logitech K345 On/Off Button Replacement, On/Off Button: étape 6, image 2 de 2
    • Pry open the sides holding the On/Off button using an opening pick.
  7. Logitech K345 On/Off Button Replacement: étape 7, image 1 de 1
    • Remove the on/off button.
Aumirius Robinson
Membre depuis le 09/26/24
574 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 16
30 derniers jours : 49
Total : 172
