Aller au contenu principal
Logitech K480 Back Cover Replacement
Madison
Madison et 2 autres contributeurs
Dernière mise à jour le December 17, 2024
8 minutes
Modérée
If you need to open up your Logitech K480, follow this guide.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Logitech K480 Back Cover Replacement, Back Cover: étape 1, image 1 de 1
    • Flip the keyboard over.
  2. Logitech K480 Back Cover Replacement: étape 2, image 1 de 3 Logitech K480 Back Cover Replacement: étape 2, image 2 de 3 Logitech K480 Back Cover Replacement: étape 2, image 3 de 3
    • Remove the four rubber feet with a spudger.
  3. Logitech K480 Back Cover Replacement: étape 3, image 1 de 3 Logitech K480 Back Cover Replacement: étape 3, image 2 de 3 Logitech K480 Back Cover Replacement: étape 3, image 3 de 3
    • Slide open battery panel.
    • Remove the batteries.
  4. Logitech K480 Back Cover Replacement: étape 4, image 1 de 2 Logitech K480 Back Cover Replacement: étape 4, image 2 de 2
    • Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
  5. Logitech K480 Back Cover Replacement: étape 5, image 1 de 2 Logitech K480 Back Cover Replacement: étape 5, image 2 de 2
    • Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
  6. Logitech K480 Back Cover Replacement: étape 6, image 1 de 3 Logitech K480 Back Cover Replacement: étape 6, image 2 de 3 Logitech K480 Back Cover Replacement: étape 6, image 3 de 3
    • Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
    • Slide a blue pick in to keep the pieces apart while you work on other areas.
    • Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
    • The loud snaps are the clips that hold the pieces together. They're not breaking and you do not need to be alarmed.
Madison
Membre depuis le 09/04/24
655 Réputation
4 tutoriels rédigés
Équipe
Utah Tech University, Team 1-8, Crenshaw Fall 2024 Membre de l'équipe Utah Tech University, Team 1-8, Crenshaw Fall 2024
UTAHTECH-CRENSHAW-F24S1G8
2 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 61
Total : 237
