Aller au contenu principal
Logitech K480 Keycap Replacement
Madison
Madison et 2 autres contributeurs
Dernière mise à jour le December 17, 2024
5 - 10 minutes
Modérée
If your Logitech K480 keyboard is missing a keycap or if it's damaged, you can follow this guide to replace it. Replacing keycaps on rubber dome keyboards can be confusing but these steps are easy for anyone to follow. Keycaps cover the buttons that actually register what you're typing. They provide a more comfortable way to type and can also allow for customization.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Logitech K480 Keycap Replacement, Back Cover: étape 1, image 1 de 1
    • Flip the keyboard over.
  2. Logitech K480 Keycap Replacement: étape 2, image 1 de 3 Logitech K480 Keycap Replacement: étape 2, image 2 de 3 Logitech K480 Keycap Replacement: étape 2, image 3 de 3
    • Remove the four rubber feet with a spudger.
  3. Logitech K480 Keycap Replacement: étape 3, image 1 de 3 Logitech K480 Keycap Replacement: étape 3, image 2 de 3 Logitech K480 Keycap Replacement: étape 3, image 3 de 3
    • Slide open battery panel.
    • Remove the batteries.
  4. Logitech K480 Keycap Replacement: étape 4, image 1 de 2 Logitech K480 Keycap Replacement: étape 4, image 2 de 2
    • Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
  5. Logitech K480 Keycap Replacement: étape 5, image 1 de 2 Logitech K480 Keycap Replacement: étape 5, image 2 de 2
    • Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
  6. Logitech K480 Keycap Replacement: étape 6, image 1 de 3 Logitech K480 Keycap Replacement: étape 6, image 2 de 3 Logitech K480 Keycap Replacement: étape 6, image 3 de 3
    • Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
    • Slide a blue pick in to keep the pieces apart while you work on other areas.
    • Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
    • The loud snaps are the clips that hold the pieces together. They're not breaking and you do not need to be alarmed.
  7. Logitech K480 Keycap Replacement, Metal Plate: étape 7, image 1 de 3 Logitech K480 Keycap Replacement, Metal Plate: étape 7, image 2 de 3 Logitech K480 Keycap Replacement, Metal Plate: étape 7, image 3 de 3
    • Remove the eight 3 mm screws using a Phillips #00 screwdriver
    • Remove the five 2 mm silver screws from the metal plate using a Phillips #00 screwdriver.
    • Remove the single 4 mm black screw by the motherboard using a Phillips #00 screwdriver.
  8. Logitech K480 Keycap Replacement: étape 8, image 1 de 2 Logitech K480 Keycap Replacement: étape 8, image 2 de 2
    • Lift up and remove the metal plate.
  9. Logitech K480 Keycap Replacement, Keycap: étape 9, image 1 de 1
    • Flip the flex circuit and rubber dome sheet over.
  10. Logitech K480 Keycap Replacement: étape 10, image 1 de 3 Logitech K480 Keycap Replacement: étape 10, image 2 de 3 Logitech K480 Keycap Replacement: étape 10, image 3 de 3
    • Using the spudger, gently press on the underside of the key and pop it out.
Madison
Membre depuis le 09/04/24
655 Réputation
4 tutoriels rédigés
Équipe
Utah Tech University, Team 1-8, Crenshaw Fall 2024 Membre de l'équipe Utah Tech University, Team 1-8, Crenshaw Fall 2024
UTAHTECH-CRENSHAW-F24S1G8
2 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 45
Total : 186
