Aller au contenu principal
Logitech UE MegaBoom 3 USB Port Replacement
Anthony Miles
Anthony Miles et 2 autres contributeurs
Dernière mise à jour le December 29, 2023
5 minutes
Facile
The following guide will show you how to replace the Logitech UE MegaBoom 3's USB port. If your speaker is having trouble charging, you’ve come to the right place. The Micro USB is used for various applications, such as powering and charging smaller devices to transmitting data between them. The port is often used as a fast-charging cable connecting smartphones and other compact devices to chargers.
This guide will provide you with step-by-step instructions for how to replace the speaker’s USB Port which is used to provide charge to the device. Before starting make sure your device is powered off and is not plugged in. Its important to note that after you have started disassembling your device, the speaker is no longer waterproof, therefore your device may suffer damages if placed in water. There are no special skills needed to complete this guide besides the knowledge of how to use a screwdriver.
Ce dont vous avez besoin
Outils
  1. Logitech UE MegaBoom 3 USB Port Replacement, General Disassembly: étape 1, image 1 de 2 Logitech UE MegaBoom 3 USB Port Replacement, General Disassembly: étape 1, image 2 de 2
    • To access all internal components, first flip the speaker upwards to where you can see the base.
    • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
  2. Logitech UE MegaBoom 3 USB Port Replacement: étape 2, image 1 de 3 Logitech UE MegaBoom 3 USB Port Replacement: étape 2, image 2 de 3 Logitech UE MegaBoom 3 USB Port Replacement: étape 2, image 3 de 3
    • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
    • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
    • Pry off the base of the speaker and remove the end cap.
  3. Logitech UE MegaBoom 3 USB Port Replacement, USB Port: étape 3, image 1 de 3 Logitech UE MegaBoom 3 USB Port Replacement, USB Port: étape 3, image 2 de 3 Logitech UE MegaBoom 3 USB Port Replacement, USB Port: étape 3, image 3 de 3
    • To remove the plastic frame that’s covering the charging board, use a Phillips #0 to remove both 2.4 mm screws.
    • Replace the charging port.
2 autres ont terminé cette réparation.
Anthony Miles
Membre depuis le 09/04/23
1 021 Réputation
6 tutoriels rédigés
Équipe
University of Memphis, Team 1-2, Sneed Fall 2023 Membre de l'équipe University of Memphis, Team 1-2, Sneed Fall 2023
UM-SNEED-F23S1G2
4 membres
7 tutoriels rédigés
3 commentaires de tutoriel
Thanks for the guide, this was very helpful!
Jason Doland - Réponse
How easy/hard would it be to upgrade the charging port to usb-c?
Nenad Tarlac - Réponse
This would be nearly impossible because micro-usb and usb type-c use different pinout (different number of pins...) and require different layout of the connection points on the charging PCB. And also the size of the usb-c socket is different.⏎
To do such modification it would require altering the charging PCB board, speaker housing (hole for the charging socket) and jumping (soldering very thin enamelled wires) from the usb-c connector to the different points on the charging PCB board.
Also this wouldn't increase the maximum charging speed, it would just be for the convenience of using one type-c cable with different modern devices.
Simon -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 45
Total : 486
