MacBook Air 11" Mid 2011 I/O Board Replacement
Introduction
Passez à l'étape 1Use this guide to replace the I/O board to remedy a broken headphone jack, left USB port, or MagSafe DC-In socket.
Ce dont vous avez besoin
Outil utilisé dans cette étape :P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
Use the flat end of a spudger to pry the I/O board cable up from its socket on the I/O board.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Remove the following five screws securing the battery to the upper case:
Two 5.2 mm T5 Torx screws
One 6 mm T5 Torx screw
Two 2.6 mm T5 Torx screws
Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
42 autres ont terminé cette réparation.
5 commentaires
Thanks. Great instructions!
Thank you so much. Just replaced my IO board and the whole process went without a hitch. I’m absolutely thrilled now that I can charge my Air without going through an extensive wriggling routine with the MagSafe connector every time.
Good day! As I can see it’s all the same with Air 2012 logic board…
I’m looking the board to replace my 2GB mid 2011, can I take 4GB mid 2012 with 1.7Ghz ..?
This was exactly what I needed!!! I replaced the I/O board and I/O board cable on a macbook 11” A1465 that was not charging or playing sound. It now works. Great explanations and details.
Thanks. Good instructions.
