MacBook Unibody Model A1342 Hard Drive Cable Replacement
Introduction
Passez à l'étape 1This guide will show you how to replace the hard drive cable.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove two 11 mm Phillips screws securing the hard drive bracket to the upper case.
Remove the 3.1 mm Phillips screw securing the hard drive cable to the upper case.
19 autres ont terminé cette réparation.
