Aller au contenu principal
Marshall Emberton Button Replacement
Asia Baldwin
Asia Baldwin et 4 autres contributeurs
Dernière mise à jour le December 27, 2022
5 minutes
Modérée
The main button on top of the Marshall Emberton speaker is used to navigate between tracks and also the volume. This guide provides detailed instructions on how to replace the main button on the Emberton Bluetooth speaker.
With constant pressure on the button, it may eventually wear out and stop working. Replacing the button is very simple and only requires a TR-9 screwdriver.
Ce dont vous avez besoin
Outils
  1. Marshall Emberton Button Replacement, Button: étape 1, image 1 de 1
    • Remove the rubber casing from the speaker by peeling it off using your nails.
  2. Marshall Emberton Button Replacement: étape 2, image 1 de 1
    • Use a TR9 screwdriver to remove the eight 1 cm screws located on top of the speaker.
  3. Marshall Emberton Button Replacement: étape 3, image 1 de 1
    • Once all the screws are off, you must pry the plastic piece off using any tool capable of sliding into the crevice. Then easily pop the piece out.
  4. Marshall Emberton Button Replacement: étape 4, image 1 de 1
    • On the back side of the plastic piece, there is a circuit which is shown in the picture. Use a TR9 screwdriver to remove two 1.2 cm screws to detach the circuit from the plastic housing.
  5. Marshall Emberton Button Replacement: étape 5, image 1 de 1
    • Once the circuit is removed, you may gently pop the button off and easily replace it with a new one.
Asia Baldwin
Membre depuis le 09/26/22
724 Réputation
5 tutoriels rédigés
Équipe
CSU Los Angeles, Team 5-1, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 5-1, Adachi Fall 2022
CSULA-ADACHI-F22S5G1
5 membres
6 tutoriels rédigés
3 commentaires
where can i find a replacement button
MANU 1907 - Réponse
The worst instruction I've ever seen in my life. If you do this, you will break your device.
cool eo - Réponse
yes, i confirme !!!
Mallet Jp -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 25
30 derniers jours : 92
Total : 2,171
