Aller au contenu principal
Marshall Emberton Charging Port Bay Replacement
Asia Baldwin
Asia Baldwin et 4 autres contributeurs
Dernière mise à jour le December 27, 2022
15 minutes
Modérée
The charging port bay is responsible for charging the battery of the Marshall Emberton. With constant plugging and unplugging, the charging port develops breakage. With the help of this guide you will be able to locate the charging port and on how to remove and replace it. The charging port bay is a small piece located by the battery. When replacing the charging port bay or locating it you must be very careful due to it's location inside the speaker.
Ce dont vous avez besoin
Outils
  1. Marshall Emberton Charging Port Bay Replacement, Charging Port Bay: étape 1, image 1 de 1
    • In order to start uncrewing any of the screws off the speaker we have to take off the protective cover.
  2. Marshall Emberton Charging Port Bay Replacement: étape 2, image 1 de 1
    • In order to get inside the speaker you will have to unscrew the screws on the side.
  3. Marshall Emberton Charging Port Bay Replacement: étape 3, image 1 de 1
    • Prying the front of the speaker where it says "Marshall" in order to get into the insides of the speaker.
  4. Marshall Emberton Charging Port Bay Replacement: étape 4, image 1 de 3 Marshall Emberton Charging Port Bay Replacement: étape 4, image 2 de 3 Marshall Emberton Charging Port Bay Replacement: étape 4, image 3 de 3
    • Once the "Marshall" part of the speaker is off this is how it will look. It's another protective layer that needs to be removed.
    • When removing all of the eight 1cm screws that are on the protective layer, will give us access to the insides of the speaker.
  5. Marshall Emberton Charging Port Bay Replacement: étape 5, image 1 de 1
    • Once speaker is opened the motherboard will be the first thing that is seen. Then you will have to look for the 6 1cm screws (Shown in photograph)
  6. Marshall Emberton Charging Port Bay Replacement: étape 6, image 1 de 2 Marshall Emberton Charging Port Bay Replacement: étape 6, image 2 de 2
    • Once screws are all off, there will be a wire (red/black) that will need to be disconnected from the motherboard.
    • Once the first wire is disconnected from the motherboard, you will then have to flip it over and do the same on the bottom side of the motherboard.
    • Once those wires are disconnected from the motherboard it will simply come right out.
  7. Marshall Emberton Charging Port Bay Replacement: étape 7, image 1 de 2 Marshall Emberton Charging Port Bay Replacement: étape 7, image 2 de 2
    • Once the motherboard is pulled out, you will be able to locate the charging port on the left side.
    • Once it is located there will be 2 1.2 cm screws that will need to be removed.
    • Once removed the charging port will be out.
3 autres ont terminé cette réparation.
Asia Baldwin
Membre depuis le 09/26/22
724 Réputation
5 tutoriels rédigés
Équipe
CSU Los Angeles, Team 5-1, Adachi Fall 2022 Membre de l'équipe CSU Los Angeles, Team 5-1, Adachi Fall 2022
CSULA-ADACHI-F22S5G1
5 membres
6 tutoriels rédigés
10 commentaires
Where can i buy that part? In europe. Thank you.
Ricardo - Réponse
Where can I purchase a replacement charging port in uk
G-REG - Réponse
Where can I buy the usb port in the US?
SLE - Réponse
Hello. Nice guide for this. Next question😉 where can i buy a New bay? 🤔 Mine is very boken 😆
/Peter
Peter Lövan Löfqvist - Réponse
Hi where can i buy the part?
Ricardo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 78
Total : 3,355
