Aller au contenu principal
Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement
Sam Omiotek
Sam Omiotek
Dernière mise à jour le March 23, 2021
30 minutes - 1 heure
Modérée
Follow this guide to replace the main PCB assembly on a Mi-T-M heater model MH-0190-0M10.
  1. Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Safety precautions: étape 1, image 1 de 2 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Safety precautions: étape 1, image 2 de 2
    • Power off the machine at least one hour prior to starting repairs. Ensure the machine is completely cool to the touch.
    • Flip the power switch into the OFF position.
    • Unplug any extension cords from the included power cord.
  2. Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Remove the right-side cover: étape 2, image 1 de 1
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the right-side cover.
  3. Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement: étape 3, image 1 de 3 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement: étape 3, image 2 de 3 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement: étape 3, image 3 de 3
    • Tilt the right-side cover down to access the PCB board.
    • Do not fully remove the right-side cover, it is still attached via the on/off switch.
    • During reassembly, ensure the display window is aligned with the LCD display.
  4. Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Disconnect all wires from the PCB: étape 4, image 1 de 3 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Disconnect all wires from the PCB: étape 4, image 2 de 3 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Disconnect all wires from the PCB: étape 4, image 3 de 3
    • Disconnect all wires from the main PCB assembly:
    • The photocell wire connector labeled CN3 on the board
    • The white wire connector labeled CN2 on the board
    • The orange wire labeled MOTOR1 on the board
    • The igniter wire connector labeled CN1 on the board
    • The yellow wire labeled ACIN1 Yellow on the board
    • The white wire labeled ACIN2 White on the board
    • The red wire labeled MOTOR2 Red on the board.
  5. Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Remove the main PCB assembly: étape 5, image 1 de 3 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Remove the main PCB assembly: étape 5, image 2 de 3 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement, Remove the main PCB assembly: étape 5, image 3 de 3
    • Use a pair of pliers to depress the locking tabs on one of the corner retaining clips securing the PCB to the bracket.
    • With the locking tabs depressed, pull the PCB away from the bracket to remove the corner.
    • Repeat for the three remaining retaining clips.
  6. Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement: étape 6, image 1 de 2 Mi-T-M Heater MH-0190-0M10 Main PCB Assembly Replacement: étape 6, image 2 de 2
    • Remove the main PCB assembly.
Sam Omiotek
Membre depuis le 02/25/19
86 073 Réputation
290 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 147
