Mi-T-M Heater MH-0190-0M10 Photocell Replacement
Introduction
Passez à l'étape 1Follow this guide to replace the photocell on a Mi-T-M heater model MH-0190-0M10.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
Flip the power switch into the OFF position.
Unplug any extension cords from the included power cord.
Use a 5/16 inch socket or Phillips screwdriver to remove the eight screws securing the upper shell, four on each side.
Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the right-side cover.
Use your fingers to disconnect the white wire harness labeled CN3 on the main PCB assembly.
