MiJia Bluetooth Thermometer (2 Battery) Replacement
Ce dont vous avez besoin
Insert the flat side of your spudger or your finger nail into the crack located the back-bottom of the device.
While inserted, use gentle force to lift the bottom up, then, use a Opening pick or your finger to remove all the clips.
The bottom should detach.
You need a spare CR2032 battery.
Remove the old battery and attach new battery from top.
You might need to wait few minute before the temperature synced up.
