Aller au contenu principal
Miadore Classic N64 Controller Buttons Replacement
angel villagomez
angel villagomez et 4 autres contributeurs
Dernière mise à jour le February 27, 2025
20 - 40 minutes
Facile
Police de grammaire
Texte bizarre
Étudiant en action
This guide demonstrates how to replace the buttons on the Miadore Classic N64 Controller. If the buttons are damaged or just misaligned, this guide can help solve your issue. This guide can also be used if you just want to change the buttons with custom buttons.
Before you replace the buttons, you may want to review the Miadore Classic N64 Controller Buttons are Unresponsive troubleshooting page for tips on how to resolve your issue.
Unplug the controller from your device before you begin this repair.
Ce dont vous avez besoin
Pièces
Outils
Afficher plus…
  1. Miadore Classic N64 Controller Buttons Replacement, Joystick: étape 1, image 1 de 3 Miadore Classic N64 Controller Buttons Replacement, Joystick: étape 1, image 2 de 3 Miadore Classic N64 Controller Buttons Replacement, Joystick: étape 1, image 3 de 3
    • Unscrew all nine 3.2 mm Phillips #000 screws from the back of the controller.
    • Remove the back panel of the controller.
  2. Miadore Classic N64 Controller Buttons Replacement: étape 2, image 1 de 2 Miadore Classic N64 Controller Buttons Replacement: étape 2, image 2 de 2
    • Remove the three 3.2 mm Phillips #000 screws holding the motherboard in place.
    • The motherboard will still be in place after the screws are removed.
  3. Miadore Classic N64 Controller Buttons Replacement: étape 3, image 1 de 3 Miadore Classic N64 Controller Buttons Replacement: étape 3, image 2 de 3 Miadore Classic N64 Controller Buttons Replacement: étape 3, image 3 de 3
    • Remove the three 3.2 mm Phillips #000 screws holding the joystick module in place.
    • Remove the joystick module.
  4. Miadore Classic N64 Controller Buttons Replacement: étape 4, image 1 de 2 Miadore Classic N64 Controller Buttons Replacement: étape 4, image 2 de 2
    • Remove the joystick by pulling it away from the needle-like object holding it in place.
    • Replace it with a new or custom joystick.
  5. Miadore Classic N64 Controller Buttons Replacement, Buttons: étape 5, image 1 de 3 Miadore Classic N64 Controller Buttons Replacement, Buttons: étape 5, image 2 de 3 Miadore Classic N64 Controller Buttons Replacement, Buttons: étape 5, image 3 de 3
    • Remove the right and left bumper.
    • If the bumper buttons are the buttons that need to be replaced, you can stop here.
  6. Miadore Classic N64 Controller Buttons Replacement: étape 6, image 1 de 3 Miadore Classic N64 Controller Buttons Replacement: étape 6, image 2 de 3 Miadore Classic N64 Controller Buttons Replacement: étape 6, image 3 de 3
    • Plastic spokes through holes in the motherboard keep it in place.
    • Pull the motherboard up with even pressure on all sides.
    • Set the motherboard to the side.
  7. Miadore Classic N64 Controller Buttons Replacement: étape 7, image 1 de 3 Miadore Classic N64 Controller Buttons Replacement: étape 7, image 2 de 3 Miadore Classic N64 Controller Buttons Replacement: étape 7, image 3 de 3
    • Remove the rubber pads. This will reveal the buttons underneath.
  8. Miadore Classic N64 Controller Buttons Replacement: étape 8, image 1 de 2 Miadore Classic N64 Controller Buttons Replacement: étape 8, image 2 de 2
    • Remove the buttons by pushing up from the bottom of the controller. This will cause them to pop out.
2 autres ont terminé cette réparation.
angel villagomez
Membre depuis le 09/16/24
301 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 5-3, Kershman Fall 2024 Membre de l'équipe CSU Los Angeles, Team 5-3, Kershman Fall 2024
CSULA-KERSHMAN-F24S5G3
5 membres
2 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 28
Total : 148
