Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement
Ce dont vous avez besoin
  1. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Removing the stand.: étape 1, image 1 de 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Removing the stand.: étape 1, image 2 de 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Removing the stand.: étape 1, image 3 de 3
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the 5 screws: étape 2, image 1 de 1
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the back panel: étape 3, image 1 de 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the back panel: étape 3, image 2 de 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the back panel: étape 3, image 3 de 3
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the four screws: étape 4, image 1 de 2 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the four screws: étape 4, image 2 de 2
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the 5 screws: étape 5, image 1 de 2 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the 5 screws: étape 5, image 2 de 2
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the cables: étape 6, image 1 de 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the cables: étape 6, image 2 de 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the cables: étape 6, image 3 de 3
    • Remove all the cables.
  7. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the motherboard: étape 7, image 1 de 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the motherboard: étape 7, image 2 de 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the motherboard: étape 7, image 3 de 3
    • Remove the four screws.
    • Pull the motherboard up and off.
  8. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement: étape 8, image 1 de 1
    • Now you can replace it with a new one.
Padraic Hoselton
Membre depuis le 08/22/17
4 366 Réputation
12 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 26
Total : 354
