Aller au contenu principal
Modal Rechargeable Wine Opener Power Button Replacement
Lauren Spicher
Lauren Spicher et 4 autres contributeurs
Dernière mise à jour le November 1, 2023
10 - 30 minutes
Facile
In this guide we will be showing one how to replace the forward and backwards buttons to a Modal Rechargeable Wine Opener in 5 quick and easy steps.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. Modal Rechargeable Wine Opener Power Button Replacement, Modal Rechargeable Wine Opener power button: étape 1, image 1 de 1
    • Carefully place the spudger under the black cylindrical ring and pry it off the top.
  2. Modal Rechargeable Wine Opener Power Button Replacement: étape 2, image 1 de 1
    • Remove the spring
    • Remove the spring guide as well to obtain clear access to the screws
  3. Modal Rechargeable Wine Opener Power Button Replacement: étape 3, image 1 de 3 Modal Rechargeable Wine Opener Power Button Replacement: étape 3, image 2 de 3 Modal Rechargeable Wine Opener Power Button Replacement: étape 3, image 3 de 3
    • Remove all four 4mm screws with a J1 Screwdriver
    • Remove the clear cylindrical cap
  4. Modal Rechargeable Wine Opener Power Button Replacement: étape 4, image 1 de 3 Modal Rechargeable Wine Opener Power Button Replacement: étape 4, image 2 de 3 Modal Rechargeable Wine Opener Power Button Replacement: étape 4, image 3 de 3
    • Apply pressure to both of the springs on the surface near the corkscrew, releasing the button port.
  5. Modal Rechargeable Wine Opener Power Button Replacement: étape 5, image 1 de 3 Modal Rechargeable Wine Opener Power Button Replacement: étape 5, image 2 de 3 Modal Rechargeable Wine Opener Power Button Replacement: étape 5, image 3 de 3
    • Remove the malfunctioning buttons from the plastic frame.
Lauren Spicher
Membre depuis le 02/15/17
101 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 15-4, Remmell Spring 2017 Membre de l'équipe USF Tampa, Team 15-4, Remmell Spring 2017
USFT-REMMELL-S17S15G4
4 membres
1 tutoriel rédigé
4 commentaires
where do you by the replacement switch?
Stan Okumura - Réponse
are there any posts for fixing the usb charging port?
Cristian Sanabria - Réponse
If the lights work, the buttons are not the problem. I can get the cork screw to turn manually, but it will not continue run beyond a few tries. Must be the motor.
tom.o@mac.com - Réponse
Could be also the battery. I will try to change the battery.
Daniel Siegenthaler -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 9,013
