Introduction
The guide will show you how to safely remove the screen and external display from your phone.
Outils
Pièces
Aucune pièce nécessaire.
Remove the rearmost panel by pushing down on the silver button, then simultaneously pulling downward on the panel.
Lift the panel off of the phone.
After removing the external casing, there are no more screws holding on the gray metal plate. Carefully separate the gray plate from the rest of the phone by simply lifting it off.
Annulation : je n'ai pas terminé ce guide.
Un commentaire
This was SO very helpful! I had dropped my V325 phone the other day and when I opened it, the screen was dark :( However, it still dialed and received calls so I was HOPING that a connection to the screen was the issue. Following this guide, I was able to get to the back of the display and sure enough, a connection was out of place. Put it back together and everything is working great!
Thanks so much!
Bob
