Aller au contenu principal
Motorola i710 Keypad Sensor Replacement
Katelyn
Katelyn et 6 autres contributeurs
Dernière mise à jour le January 28, 2014
10 minutes
Modérée
Images incohérentes
Once the back cover, battery, and motherboard have been removed, the keypad can accessed.
  1. Motorola i710 Keypad Sensor Replacement, Battery Cover: étape 1, image 1 de 2 Motorola i710 Keypad Sensor Replacement, Battery Cover: étape 1, image 2 de 2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 Keypad Sensor Replacement, Battery: étape 2, image 1 de 1
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 Keypad Sensor Replacement, Motherboard: étape 3, image 1 de 3 Motorola i710 Keypad Sensor Replacement, Motherboard: étape 3, image 2 de 3 Motorola i710 Keypad Sensor Replacement, Motherboard: étape 3, image 3 de 3
    • Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge.
    • Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort.
    • The motherboard should now be completely disconnected from the phone.
  4. Motorola i710 Keypad Sensor Replacement, Keypad Sensor: étape 4, image 1 de 2 Motorola i710 Keypad Sensor Replacement, Keypad Sensor: étape 4, image 2 de 2
    • Once the motherboard has been removed from the keypad, the keypad sensor can be detached from the phone at the hinge.
    • Gently pry off the cable connecting the keypad sensor. The keypad sensor should now be completely separated from the phone.
Katelyn
Membre depuis le 10/22/12
1 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 14-2, Benson Fall 2012 Membre de l'équipe Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 membres
17 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 334
