Aller au contenu principal
New Nintendo 3DS Cover Plate Replacement
ethan2226
ethan2226 et 2 autres contributeurs
Dernière mise à jour le May 22, 2024
5 minutes
Facile
Photos d’action
Tutoriel réalisé par la communauté
  1. New Nintendo 3DS Cover Plate Replacement, Placing the system on a flat table.: étape 1, image 1 de 1
    • Ensure your device is powered off before proceeding. Failure to do so may result in electrical shock or damage to the device.
    • Place the system on a flat stable surface.
    • The Cover Plates will ONLY work with the New Nintendo 3DS. They are not compatible with New Nintendo 3DS XL or any other Nintendo system.
  2. New Nintendo 3DS Cover Plate Replacement, Unscrewing the back cover plate.: étape 2, image 1 de 1
    • Use a size #0 phillips-head screwdriver to loosen the screws from the back cover plate. The screws are attached to the cover, so they will not come out completely.
  3. New Nintendo 3DS Cover Plate Replacement, Prying up the back cover plate.: étape 3, image 1 de 1
    • Use the nub on the end of the stylus , a fingernail or a plastic opening tool to gently pry on the small slots on each side near the L and R buttons. Once the cover plate begins to separate from the system, gently remove it.
  4. New Nintendo 3DS Cover Plate Replacement, Prying the front cover plate.: étape 4, image 1 de 1
    • Use the nub on the end of the stylus , a fingernail, or a plastic opening tool to gently pry on the small slots on each side near the L and R buttons. Once the cover plate begins to separate from the system, gently remove it.
  5. New Nintendo 3DS Cover Plate Replacement, Attaching the front cover plate.: étape 5, image 1 de 1
    • Attach the new front cover plate.
  6. New Nintendo 3DS Cover Plate Replacement, Attaching the back cover plate.: étape 6, image 1 de 1
    • Attach the new back cover plate and tighten the two #0 phillips-head screws.
You have changed the cover plates on your New Nintendo 3DS system.
5 autres ont terminé cette réparation.
ethan2226
Membre depuis le 12/26/15
175 Réputation
1 tutoriel rédigé
Un commentaire
Hey, this isn't really related but are those custom plates or decals? If so please enlighten me on where to find them. They look really good and I can't find any like this. Thanks in advance!
bobcantfixit - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 74
30 derniers jours : 195
Total : 11,692
