Aller au contenu principal
Newport e360 Exhalation Flow Sensor Replacement
Lauren Ochoa
Lauren Ochoa et un autre contributeur
Dernière mise à jour le July 3, 2020
10 minutes
Facile
Replacing the Exhalation Flow Sensor should be relatively quick and easy. There are no tools needed in this replacement. Make sure to give yourself time to thoroughly read through the instructions.
For more information on replacing the exhalation flow sensor, please refer to page 4-2 in the service manual.
  1. Newport e360 Exhalation Flow Sensor Replacement, Exhalation Flow Sensor: étape 1, image 1 de 1
    • Turn off ventilator before starting this repair.
    • Shut off or disconnect the air and oxygen gas supplies before starting this repair.
  2. Newport e360 Exhalation Flow Sensor Replacement: étape 2, image 1 de 1
    • To avoid damaging equipment, always use standard electrostatic discharge (ESD) precautions
    • Put on an ESD wrist strap or ESD gloves
  3. Newport e360 Exhalation Flow Sensor Replacement: étape 3, image 1 de 1
    • Open the Front Panel Door on the lower left front of the ventilator to expose Exhalation Valve EXH2105A and Flow Sensor FLS2101P.
  4. Newport e360 Exhalation Flow Sensor Replacement: étape 4, image 1 de 1
    • Remove the Exhalation Valve EXH2105A by releasing the retaining latch.
  5. Newport e360 Exhalation Flow Sensor Replacement: étape 5, image 1 de 1
    • Disconnect the Flow Sensor Cable CBL2123P from the plastic body of the Flow Sensor FLS2101P by pulling cable straight up. Do not twist.
  6. Newport e360 Exhalation Flow Sensor Replacement: étape 6, image 1 de 1
    • With a twisting motion, pull the plastic Flow Sensor FLS2101P away from the outlet of the Exhalation Valve EXH2105A.
2 autres ont terminé cette réparation.
Lauren Ochoa
Membre depuis le 04/13/20
165 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S7-G21, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S7-G21, Paton Spring 2020
CPSU-PATON-S20S7G21
3 membres
3 tutoriels rédigés
2 commentaires de tutoriel
I need this Exhalation Valve EXH2105A part, does anyone have a replacement?
Remigio Rodriguez - Réponse
I need this
Cable NEWPORT GR-CBL2123P Flow Meter Parts P/N GR-CBL2123P
Please confirmwd to edisonmanullang@gmail.com
Thanks
Edison Simanullang - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 596
